Starrett Repair?
Starrett Repair?
Starrett Repair?
Tony - Memphis
>I was working in the shop yesterday (making a leg pattern for a tea table project) and noticed that my little 4" Starrett combination square was not square anymore! Never noticed it before. Haven't dropped it or anything terrible like that. Just wonderign if anyone has ever had any repairs done to a Starret? I checked it against several machinist's squares and a larger Starrett and they all showed the same amount of error - just a hair under a sixteenth over three inches. Enough to see.
Tony
Re: Starrett Repair?
Joe Rogers, Northern Virginia
>If you look in the bottom of the groove where the rule slides on both sides of the pinch bolt you can see two raised bumps that are used to calibrate the square. See if one of the bumps is damaged or has a burr on it. These can be dressed down to true the square. I know Starrett will do it and I'm not sure I'd try it myself.
JR
>Someone - FWW? - described how to do this. An auger bit file is about ideal for the purpose, I think - safe face, and narrow.
Did you say?
Marv....... Northern California Lake Co.
>one sixteenth out of square in 3 inches?!!
That's like not even close to square.
How could you not have noticed it long ago?
You should be able to just look at it and tell it's not square if it's that much out.
Marv
Now, Marv...
>He did notice it.
I find I tend to assume that Starrett stuff is bulletproof, but of course it's not.
Re: Now, Marv...
ThomD
>Check the rule itself, and the cast bit to see if they are actually straight. It would be worth investigating how this error happened. If you didn't break it and it didn't wear, and it isn't gummed up or rusted, what are the options? Probably just a little wear.
If there are two nibs, you could adjust them by filing that is slow enough that it shoudn't be dangerous. I wonder though if they are intended to be hit with a punch? I have a Starret, but am always scared of the wear so I don't use it except when an adjustible is really needed. Sorta silly.
Per some authority or other
>the nibs are supposed to be filed.
Irrelevant side note
>I've got a few Brown & Sharpe tools, including one center head with rule and, from my uncle, a full combination square set (rule, square/45 head, center head, protractor). Each of the center heads has really neat adjustable nubs - a screw coming up under the rule's edge on each side of the clamp bolt, and another screw on each side to lock the first screws in position. For reasons beyond my ken, they didn't apply this inspired solution to either the square/45 head or the protractor head (it would have been a little harder - the casting on the center head gives a clear shot to install the screws, not so on the other heads - but, if they'd solved that problem, they'd have been ahead of Starrett).
Re: Another irrelevant side note
Wiley Horne--So. Calif.
>Bill,
I hate to hijack your really excellent irrelevancy with my piddly irrelevancy. But I have gotten to a point in my CRS development, that if I don't say it now, it won't happen.
You have reminded me of one of the more serious tool issues of our time. This is in regards to Starrett. Does anyone have an idea why it is that Starrett does not use a satin chrome rule in their double squares? So you can make out the marks. The combination squares all have satin chrome as standard, but it isn't even an option in the Starrett double squares.
Wiley.......grumbling
chuckbeck in cent il
>Thanks guys, I just got one at an auction right before I ordered one new. It is slightly out and I was slow to pick up my file for the body. Incidentally I mostly use metric so I don't actually use the measurements on the rule, I use my shinwa for that. However the supplied rule when filed sharp and true is beautiful thing.
chuckbeck
Oops....
Tony - Memphis
>That's pretty square to a carpenter! Actually, I mis-spoke. Its not near that big. Probably a 64th. Enough to see. I checked for burrs, gunk, etc. Checked the flatness of everything. Its just out. I had noticed that my saw cuts never matched my marked lines. Didn't think much about it. I have only been using this thing a few years, so I'd be surprised if it had worn that much (and only on one side). I'll send it to them and see what they can do. I have no idea what they charge for such repairs, but I wouldn't think it would be too much. I've really gotten attached to this thing. It is the perfect tool for many tasks. Just the right size. Makes the 12" comobo seem huge and heavy (that one is square though!).
Tony
>The satin chrome rules aren't standard in combo sets. You can get them from Starrett in either finish. The satin chrome rules are way more popular though so thats what most resellers offer. I got a 6" satin chrome rule to replace the standard finish rule on my 6" combo square so I bet you Starrett makes the rules in satin for the squares too. I've been wrong before too :-)
Joe
>Just checked and the rules are available for the double squares in satin chrome but they are just not packaged with any sets. The combo square sets can be had both ways not the double squares...? Wonder why? I agree the satin chrome is the way to go. I may buck up and order the satin chrome 4" rule to replace my double square rule now just cause you brought this up...Thanks, (grumble grumble)
JR
Re: Oops....
>Tony,
Are you an eBayer kinda guy? Lots of machinist tools on eBay all the time. You can probably find close to a new one for less than you can get that one fixed.
On the other hand, doesn't take much of anything down in that groove to throw the blade off a 1/64". I suppose if it has been used extensively over the years, the blade could wear in the center area more than at both ends. Try flipping the blade over, it might be worn more on one edge than it is on the other.
I know what you mean about tolerances and carpenters. Plus-minus 1/4" is spot on for some. LOL
For a machinist, plus-minus 1/64" is like a mile.
Marv
>Joe,
I really appreciate your running this down! And am glad to be wrong when I said satin was not even an option for double squares. Where did you find the satin blades for double squares? MSC? I'm definitely going to order.
Wiley
>I have ordered from Starrett directly. However that was for repair parts for a micrometer. That said I don't see why you couldn't order rules direct also. I haven't gotten into it enough to locate a retailer. I will scan ENCO tomorrow at work an see if they stock the rules. MSC is another good option to check.
The link for the catalog page for squares is:
http://catalog.starrett.com/catalog/catalog/PLH2.asp?NodeNum=21489
The 4" blade is definitely available but the 6" may not interchange...but I don't see why not.
JR
>Joe,
I think I get it now--you're saying to check whether the satin blades for the combination square are interchangeable into the double squares?
I just did some checking at my bench, for the 6" double square. The 6" combination square blade is distinctly smaller than the 6" double square blade.
Oddly enough, the 12" combination square blade comes closer to fitting the 6" double square body, because they're both 1" wide. But the 12" blade mics at 0.09" thick compared with 0.082" thick for the double square blade.
I'll check with Joel and see if he can put together a 4" double square with satin blade, from the components.
Thanks a lot!
Wiley
>"I think I get it now--you're saying to check whether the satin blades for the combination square are interchangeable into the double squares?"
Exactly! I don't have a 6" double square to check. Glad you do. :-)
BTW the 4" double square blades all have the same base size so you are good to go there. Satin blades are available in 4" for sure.
Joe
Success *LINK*
>Thanks Joe,
I wrote Joel and he not only has the replacement satin blade for the Starrett 4" double square--he also informs me that the square w/satin chrome blade is a standard item. Ordered this morning. There's a link below in case anyone else is interested.
Wiley
Starrett double squares at TFWW ("Joel")
