Letter Knife Mk 2
Letter Knife Mk 2
Letter Knife Mk 2
>You may want to forget the letter knife I posted here last week. Although it was a nice knife (if you had murder on your mind), it was nothing like a real letter knife. Since it was to be a birthday present for my brother, I decided to make another one.
Below is the new letter knife - it is VERY different to the original - together with the presentation box I built for it. The box is designed to open on a desk and provide easy access to the knife. My brother will use it.
The only part that I have not yet completed is the "holder" for the knife. I had something in mind similar to the holder for the brace I posted a short while ago.... mini stands ... but I thought to angle the knife at about 30 degrees off the horizontal (i.e. downward). What do you think? I welcome your ideas for this area.
The other feedback I'd appreciate is where to place an inscription. I thought to have the blade inscribed. The alternative is a brass plate on the box.
Here's the box. It was coopered out of Jarrah ...
The box flips open ...
(this is, as mentioned, without the holder)
And a few close ups. Reminder - the blade was a Stanley plane blade. The handle is She-oak.
Re: Letter Knife Mk 2
Me like ! . . .
steve mackay
>Sorry, I'd have to sharpen it. It'd be a SWEET trimming knife !
Nice, as always *LINK*
>The little "stands" you used for your brace make sense; another approach that might make sense* would be a sort of french-fitted ramp for the blade (without the foam, but perhaps with the leather - I've been told that chemically tanned leather can corrode steel, while vegetable tanned won't, but have no direct experience), angled down toward the point sufficiently to give good finger clearance at the handle - oriented, of course, to his natural hand (left or right). Tapering the sides of the French-fit trough in the ramp outward, and putting the leather just in the bottom would let him set the knife down casually, after which the knife could find its own way to its proper resting place.
Either way - stands or ramp - the handle should be fully available to grasp, or as close to that as possible under the lid.
The box is very pretty - is the base heavy enough to stay flat to the desk while the lid's open? It looks like the lid might want to rotate backwards, flipping the base upward at the hinge edge (though, since your Coriolis effect works in the opposite way to we up north, maybe not - teasing). My immediate reaction - though it may look very different in person - is that the base appears small relative to the lid. If either the functional or aesthetic issues call for a larger base, you could make a pedestal or skirted base to add weight (physical and visual) to the base, and this could give you a locale for a brass presentation plate.
As I think about it, though, I'm intrigued by the idea of a brass plate inside the box, on the base in front of the knife holder. A "secret" location like that is more intimate, and would remind your brother of your love for him every time he opened it.
My US$0.02, worth what you'd be paying for it if the Internet were free.
*As I read back through this before posting, I am amused to find myself becoming more and more convinced that my idle suggestion is The Right Idea.
Google sure didn't know a lot about French fitting
Wiley Horne--So. Calif.
>Hi Derek,
Very handsome box, and the letter opener is really grand now! The coopering was a great idea (and execution!).
Two ideas come to mind on how the letter opener is presented inside the box. However, both would require some sort of an enclosure on the base. Idea 1: The letter opener could be sitting on a leather pad, and leather fits the idea of a desk accessory. But then the pad would seem to require some sort of a low enclosure. Idea 2: High end Japanese planes frequently come inside of a box, loosely wrapped in black or navy blue silk. if the base had a low enclosure, just fold some black or navy silk into the bottom of it, and plunk the letter opener down on top of it. Done.
He'll be thrilled, whatever you decide. The opener really wants to be used. The figured she-oak is outstanding!
Wiley
I'm wondering, Derek,
Bruce, a MN Galoot
>where you get the time to do all this magnificent work. It seems as if every project you touch is truly wonderful, painstaking and time-consuming. Do you have a clone?
Bruce
Tom Colligan
>Derek, how about weighting the bottom and covering it with cloth of some type; maybe in a flexible pillow appearance.
What degree bevel did you set the TS to correctly cooper the top?
Unbelievable work, Derek. My hunch is few people will feel comfortable offering advice to you. Tom
>Tom, I have collected enough info/pictures to write up a full tutorial. I will put it together (but not today!) My method of glueing the coopers pieces together does not require a jig of any form!
Now to finish the box.
Re: Nice, as always
>Hi Bill
The base is lighter than the top. However, the top lift up and rolls over and then rests in the same plain as the base. I did think about a handle for the lid, but the curve makes it easy to grasp and I wanted a clean front.
Ltr opener
Philip Duffy
>Abolutely up to the great standards we expect to see when you create something! BZ. Phil
It is finally complete!
>My fellow inmates
Many thanks for all your comments so far. They are much appreciated.
Well, for better or worse, the box is complete and the knife is inscribed.
Here's the box (again) ...
And here is the presentation ...
Thanks for the idea for presentation Wiley.
That really completes it
>Will you consider adopting me?
Very impressive work, Derek!
Marv....... Northern California Lake Co.
That worked out wonderfully!!
>Your brother will have warm fuzzy feelings forever about this gift.
Wiley
IT'S ALIVE!
Scott Burr in Ben Lomond, CA
>Oh fellow inmate, that's sweet (or is it the meds...;)
Love the box, looking forward to yet another lesson so I can glean a bit of knowledge from you.
Purple, great choice. It's my favorite color.
Or is it Plum...
Oh yea, You should have tucked and rolled the fabric vato.
