Shooting Board query
roninkokomo
>How are the fixtures for the Charlesworth Shooting Board fixed to the main board during use??
THanks
roninkokomo
THanks
Re: Shooting Board query
Scott in Montana
>I have a couple different shooting boards for doing 45 degree joints; on these the different fixtures are screwed to the boards. For other applications I use double sided tape to hold custom angle fixtures to my 90 degree shooting board.
How could you ever get along without a shooting board?
Scott in Montana
roninkokomo
>Scott,
I thought it was probably screws, but the drawings or photos do not show that.
Ron
Fence design
>Hi Ron
I can't say what David does. I was waiting to read if others might know. However I can show you what I do. This is a little different, but it works very well for my fence design.
First off, I build a little (micro-) adjustability into my fences.
The bolt on the right is the pivot point, while the bolt on the left is the adjustable side. The fence has a slightly oversize hole, so that there is about 1/4" adjustment fore-and-aft.
(This fence also has a sliding end to take up wear over time, but that is not essential).
If you look carefully you will see a small bolt hole in the centre of the fence. More in a moment ..
The board in action ..
There are two accessories. A mitre fence ..
.. and a Donkey's Ear ..
Both are connected to the fence via the bolt hole mentioned earlier.
The advantage of this method is that you automatically add micro-adjustability to these fences as well. This becomes very useful when you want to ensure gap-free joints:
David Brown
>I have watched the David Charlesworth videos 2 or 3 times, (but not recently) and I'm pretty sure he does not attach them at all. Rather he uses a clamp to clamp the fixture to the shooting board. His bench has a removable bottom of the tool tray and so he can get a big F style clamp in far enough to hold on the miter fixture and I think he does the same for the bird house fixture. That's my memory.
However, even though I like almost everything I see Mr. Charlesworth do, I don't do it that way. I was really interested in the ability to adjust the fence exactly so I do basically what David Finck does, but do it on a Charlesworth style shooting board. You can see Mr. Finck's plan at Fine Woodworking's website (you may have to be a member?) The idea is to have a small piece screwed down and the your main fence has a rabbet that fits over the small piece. Then you use screws and washers in oversize holes to allow you to put shims (the magic of blue tape!) against the small piece as needed so the main fence has an accurate angle. Although Mr. Finck does not do that with the 45 miter, I did do that also with the 45 miter. The beauty of this system for me is that the shims are not pulling your workpiece away from the fence, which depending on where you need your shims could be leaving a gap between the fence and your work piece. With Mr. Finck's method, the shim is between the fixed fence and the adjustable fence, which I like.
Having said all that, I was impressed with Derek Cohen's shooting board, so that would be another way to go.
Good Luck.
--Dave
Re: Fence design
Victor Parisian
>Can you post a sketch and explanation of the mechanics of the adjustable bits? I'm a little slow headed here this morning.
Victor - enjoying my coffee on a quiet, cool and rainy Saturday morning in Houston
Re: Fence design *LINK*
>Hi Victor
I can do a bit better than that. There are pictures at the link below.
Thanks Derek. Those ramped boards are gorgeous.
Victor Parisian
>I remember now that you posted those some time back. I may have even printed out that series and then went on to other things.
Thanks again.
Victor - drying out in Houston
Thanks Guys
roninkokomo
