Haa It Comes To This?
charlie belden
>In the just arrived March 2009 LN "flyer"
- Drawbore Pin Pair - $90. These are 0-1 Tool Steel, hardened to Rockwell hardness 60-62.
Two pair are recomended for door repair.
Since there's no wood that I know of that's hard enough to require a draw bore pin to be hardened to Rc 60-62, or that it be made of 0-1 tool steel for that matter - is there an actual User (as opposed to Collector) market for a pair of tools like this? If so, how in the world were all the draw bore pegged mortise and tenon joints able to be done without one of these things?
Can titanium measuring tapes, hardened to Rc 65 - with cryogenic treatment be LN's next new tool release?
Re: Haa It Comes To This?
Chris Friesen
>Must be the season...
Lee Valley recently came out with a stainless steel drawbore pins in two sizes. (Presumably stainless so as not to mar the surface of the wood with scraped-off rust particles.) A pair is $59 CAD.
Tools for Working Wood has Ray Iles drawbore pins, with an eccentric shaft, for $89 or $99/pair, depending on size.
wilbur
>Personally, the first thing that came to mind when I saw these was that I don't even use drawbore pins for making drawbored M/T joints. Maybe I've been lucky so far, but I haven't found them necessary.
There are plenty of things I've bought that I subsequently find myself not using, but in this case I know these tools would be resting on the shelf.
Jack Guzman from Maine
>I use drawbore pins all the time.Keep finding them in flea markets.Usually on the floor in a box of unidentifiable junk.I have 4 so far.
I have found that stainless would be handy.If I forget to clean one after use,the water in the glue rusts the shaft,fast.However,I can see no reason for hardening one,unless maybe you want it to double as a burnisher.---Jack
Suggestion for Jack
Patrick Gibbons, Katy, TX
>I think you're right about hardness. In fact, I would think that toughness was more important. But I'm sure you're familiar with oil darkening for steel. Just lubricate the pins you have with motor oil and heat in the oven on low heat for an hour or so. Or use vegetable oil, if you think SWMBO might object to the smell. Just like seasoning a cast iron pot, it will turn your pins black and make them highly water resistant.
Depleated unranium plane cutter !
steve mackay
Now we are getting somewhere...
Victor P
>I think the extra heavy Depleted Uranium #4-1/2 C smoother (diamond lapped to +/-.000001" with the ultra high frog angle and extra thick N2 cryo treated diamond honed blade is just the ticket for that Australian Jara Wood with reversing grain.
Victor - ducking and running
I like that
>That sounds like a great idea. thanks Patrick
