The Galoots Way
The Galoots Way
The Galoots Way
>My brother's 50th birthday is coming up soon. He lives in Sydney and my wife, son and I will fly in for surprise party in a couple of weeks.
What to get him for a gift? He is wealthy and does not lack for anything. Anyway his wife made it clear that gifts were on the no-no list. Of course ...
So I decided I would make something for him, a letter knife in a (Huon Pine) presentation box. He would use one. I am part way there. The knife is done - should finish the box next weekend. I thought I'd show the knife for comments as I have not made one before. There is still time to do something else.
My family and I were touring around Tasmania at the beginning of last year. We visited the Salamanca Market in Hobart, where I found a whole bunch of Stanley #4 blades. Now Stanley used to have a factory in Hobart producing planes and blades. This closed down about 20 years ago.These blades were old stock. Interestingly, they were not heat treated, and for me this was perfect since I wanted them for knife blades.
So one half of one of these blades became the letter knife. The steel was grown to shape. I used the bench grinder to add a double bevel on both sides of the blade. Each side is about 25 degrees. I then honed it freehand on diamond- and waterstones to 5000 grit. The scales are Jarrah and connected with a dab of epoxy and brass pins.
I heat-treated the blades with a torch and a bucket of water. Taken to cherry red and a file skated across the steel. I used the torch again to bring it to a browny straw, then quenched again in water.
The blade is 4 3/4" long and the total length is 81/2".
The pictures show one side. The other side is identical.
It cuts paper.
Now to do the box.
What do you think?
Re: The Galoots Way
Re: The Galoots Way
Bob Demers
>OMG NOS Stanley blades turned into... Kidding :-)
You sure do nice work Derek, im sure your brother will appreciate.
More so since you made it, and there is some part of Australian tool makers history in it (Stanley), tr�s cool mon ami.
Bob
Re: The Galoots Way
Re: The Galoots Way
Patrick Gibbons, Katy, TX
>Derek, that's a fine stiletto you've made there. Nothing needs to be changed. With that said, I would be thinking of other things to add to it for next year's birthday; a stamp holder, a blotter, magnifying glass, small boxes for paperclips and other small items. There is nothing more pleasing than a small useful item one uses daily that is finely crafted and brings a smile to the face every time it's picked up.
Re: The Galoots Way
Exibit "a"
HC Sakman --- Victoria,BC. CANADA
>Hi Derek,
Knife looks great; Great enough that can be a murder weapon! ;-) Sorry with the title. Your photo of it reminded me that. I am sure it'll be cherished everytime it's used.
Chico...
PS: Do you have a LV store in Perts? ;-)
Re: The Galoots Way
Re: The Galoots Way
Bill Tindall, E.TN
>I would like to take it trout fishing. Would you describe how the pins get fastened in such that they hold the wood parts on? Are they glued, peened, ??
Re: The Galoots Way
Re: The Galoots Way
>Very nice. The little "waist" in the blade right at the handle makes very clever use of the hole at the end of the cap iron screw slot.
Typically lovely work, Derek.
Re: The Galoots Way
The handle
>Hi Bill
I did all this work this Easter Monday afternoon (today), and was rushing to get it all done, so did not take pictures as I usually do. Anyway it is my first "knife" (outside of all the marking knives and a couple of chip carvers), so I was feeling my way.
Having made the blade, I prepared for the scales and rivets by drilling the blade haft. The steel was still soft at this stage so drilling it was not difficult.
I prepared the scales/handle by cutting a piece of Jarrah close to size, then bandsawing out a mortice. You can see it here ..
I used the drilled haft as a template on the Jarrah, then drilled it all the way through on my drill press (for accuracy).
The holes matched the brass rod I had on hand.
The steel haft was given a lick of epoxy and pushed into the mortice, and then the brass rivets were pushed through the holes. All lined up nicely, TG.
Once it was dry, I ground it back. The brass pins did not require peening, just smoothing.
Finally, I could finish shaping the handle, sanded to 800 grip, and given a coat of buffed Shellawax.
Re: The Galoots Way
Re: Exibit "a"
Alex Grigoriev
>Better: He has "primae noctis" privilege!
Re: The Galoots Way
Re: The Galoots Way
Alex Grigoriev
>Derek,
I think the letter knife blade should not be razor sharp. First, it will be to dangerous to keep it on a table full of litter; second it will stray off the crease. It should be a bit dull.
Re: The Galoots Way
Re: The Galoots Way
>Hi Alex
Interesting. What I have - by chance - seems a good compromise. The bevels are 25 degrees on each side, in other words, meeting at 50 degrees. The edges are clearly sharper than a rounded end, but they are not like a kitchen knife. In practice - on envelopes - it works well.
Re: The Galoots Way
Re: The Galoots Way
ThomD
>I think you are thoughtful, and he is probably safe in most alleys at night.
If he was a Lee Valley collector, something in Black and Brass like this one, maybe given a side rebate look would be cool.
Re: The Galoots Way
He'd better enjoy it. Otherwise...
Scott Burr in Ben Lomond, CA
>You can always stick him with it!
Just kiddin'
I think it's a great gift.
