Spring
Wiley Horne--So. Calif.
>Hi Derek,
Just noodling around on something.....Suppose you had a crotch section, where a branch emerges from the trunk. So you have an acute-angle L, the trunk section forming the short arm of the L, and the branch section making the long arm of the L. The trunk section is tenoned through the base of the clipboard and made tight with a wedge inserted from the underside. The branch section comes to rest on the clipboard surface, and papers can be inserted under it. Because it is a crotch section, the branch will not break off the trunk section when lifted up (In theory!). If you wanted to make it fancy, carve the piece to include an upward extension of the trunk section, so you could push on it with your thumb, which would raise the branch arm off the clipboard surface, the easier to insert your papers.
There are other articulated 'springs' that could be made, but if this worked, the spring action would be integral to the way the fibers are arranged where the limb joins the trunk.
Wiley
