Another saw till *LINK*
>David Miller's recent post about his saw till (link below) has inspired me to embarrass myself by posting mine. I use a similar approach to David, but, due to limited shop space and completely disorganized habits, my saws hang from the ceiling joists. The 9+ foot distance floor to "ceiling" (by which I mean the bottom of the joists for the second floor of our old tankhouse, my shop being on the first floor) gives me plenty of headroom, but, to get to the saws, I have to climb up on my bench.
I keep one crosscut saw and a utility backsaw tucked into the stud bay behind the bench - if I could back up far enough in my shop to take a full picture, you'd be able to see them in the same bay where Yosemite Sam lives (visible just left of center at the bottom of the pic).
This is NOT my permanent intention. When I get to organizing the shop, I plan to build a proper saw till, probably the design most folks here favor; this has served me, if that's the phrase, for about five years now, or maybe more (losing track of time).
You can also see my brace till, bottom left. The eggbeater till is just the same, but out of sight behind the handscrews.
David Miller's till is more organized than mine
Re: Another saw till *LINK*
Earthquake proofing tools stored on dowels
>Living in shaky country, I was concerned about having the saws I have slowly acquired getting knocked to the floor and damaged in an earthquake - and, if I should be in the shop at the time, working right below the saws, concerned about having me damaged as well (granted, the distance is short enough that, at 32 feet per second per second acceleration, I wouldn't get crushed, but a rain of saws would get my attention).
I have an old truck inner tube from which I cut some wide rubber bands (it's been years - I think this one is from the Studebaker, which I hadn't run since my 32-year-old was five - but it should be possible to scrounge one from a tire shop that deals with trucks or farm implements, although inner tubes are probably going the way of fuller balls). I nailed the band to the joist, just above the dowel. It's sized to stretch over the end of the dowel. Easy to remove and replace, and I'm fairly sure it will resist sideways movement of the saws enough to keep them in place.
I need to do something about the lumber stored up there, too; another shop project getting in the way of actual woodworking.
Marv....... Northern California Lake Co.
>Bill,
Nice shop! It should be included in the Shop Shots. I'm paricularly impressed with your electrical wiring. Wish I had done mine that way when I built my shop instead of hiding it all under the sheetrock. :))
Marv
As found
>Rewiring the shop is another project - this is the last of the knob and tube left, if you don't count the barn, which we have disconnected after looking at the uninsulated wires feeding the barn's service.
>Bill
You should be ashamed of yourself :) Heh.
Actually, my small stash resembled yours ... with the exception of the live power cable .... until a few months ago. The problem with dowels is that you have to lift off all the saws until you get to the one you want .. which is always the last one!
Can you post a close up of the dowels you use? Did you fit them at any special angle? Power or hand drill?
I am teasing.
This is what replaced my dowels. I posted it a while back .. the one with the dovetails facing the wrong direction.
I used round dowels from the hardware store
>The next version of this will use riven, hand-shaped dowels, of course - a chance to use drawknife and spokeshave.
Clever saw lock you have there!
Scott Burr in Ben Lomond, CA
I'd use
Bruce, a MN Galoot
>some of that left-over rebar from your curb project. That's sure to be earthquake proof!
Bruce
Re: I'd use
Victor Parisian
>Store bought by whom? That was likely a generation ago. :>)
Victor - heading to bed
