Seems it was used for hewing...
Alan DuBoff
>Todd,
Definitely a goosewing axe as you point bout, but most of the reference I can find on the web do say that it is used for hewing.
Pretty in depth study at the following link:
http://findarticles.com/p/articles/mi_qa3983/is_200112/ai_n9013872/
Here's another online link that also mentioned it is for hewing:
http://books.google.com/books?id=x5ZiYCZRdHwC&pg=PA28&lpg=PA28&dq=goosewing+axe+function&source=bl&ots=1B7CetekqK&sig=WRl1oAragftrWA1oN1MzG2xVHOA&hl=en&ei=defbSciLDJrMMKrZlNUN&sa=X&oi=book_result&ct=result&resnum=1
Very cool looking axe, IMO. It is a tad different than the design that Mackie shows which has a ridge perpendicular to the cutting edge. Do you know, is that ridge there to make the broad axe head more durable? Have you seen the style that has a ridge on the bevel side?
Mackie shows it as having soft iron from the eye to about half the blade (where the ridge extends to), and steel on the edge, so it is clearly laminated in his example.
However, Mackie also shows it as being a straight edge, and not curved.
I take your word on the steel, as many of the American broad axes I've seen are fairly pitted and do look like pretty crappy steel, which is why I haven't bought any. Still would like to have one though. :-) (I do have a hatchet with a chisel edge)
Although not clear, it would seem the offset handle, along with the chisel edge would distinguish it for hewing, maybe not.
Whether for hewing or not, definitely a cool looking axe.
Cheers,
Alan
