How was this made?
How was this made?
How was this made?
Bill Tindall, E.TN
>As I understand it the white squares are inlayed into the mahogany fretwork. Two questions.
1. How were the square holes made as well as how were the square white pieces made to perfectly fit into the square holes?
2. The mahogany is chemically stained with dichromate. How does one do this and keep the white pieces from staining as well.
In case you guessed, I would like to make this tray.
Re: How was this made?
Chuck Kettler Greenwood IN
>The piece has the appearance that perhaps the off color square pieces are veneer and were put in place before final assembly and the lattice work laid over and glued in place. That would provide the opportunity to utilize dichromate to stain the mahogany before final assembly. The veneer would have to be cut to size of the lattice opening or be very thin so that a noticeable gap was not observed. Let us know how you approach this after you decide.
I imagine that the "holes" were first sawn out with a fret saw, then cleaned up with a file or very fine rasp. You would need to use a guide block to file square to the face. Each "white" block would have been sawn and planed to fit. If I were making this (I should be that good!), then I would leave the block long by at least 1" - 2" with the last inch tapered so that the "block" could enter the square easily. Once a good fit was created, glue it in flush, then saw off the waste on the inside and pare smooth.
Do the mahogany first. Add the infill later.
I would never have guessed ... :)
Bill, you're not very stealthy are you...
Patrick Gibbons, Katy, TX
>You're supposed to find out, make it and then show it to us leaving us to wonder, "How in the h@#% did he do that?" You just have to start thinking more about elevating your rep here Bill. All seriousness aside, I will be very impressed when you finish your version. You notice I said when and not if.
Warren in Lancaster, PA
>I think the alternating wood section was made like banding. A piece of thin mahogany was glued to thicker lighter wood, then sliced crosscut in perhaps 3/4 inch strips and glued together to make a sandwich. Then sliced again ( 3/16 strips or so) to make sections of banding with perhaps five light wood sections. Then the banding sections were glued together with top (wide) and bottom (narrow) strips of mahogany. This is much easier than trying to fit in four dozen little pieces. You want to cut out the fretwork after gluing the banding in so that the fretwork design matches up with verticals in the banding.
If you stain with chemical stains like chromate, some woods react much differently than others. You will have to experiment with your materials. You might also try alkali.
I am curious how old this thing is; some things don't quite look like 18th century. If you could examine the thing closely, perhaps with a lens, you could get more clues.
Dean J in MN
>Bill --
Can you see the backsides of the lighter squares? Are the joint lines as tight in the rear as the front? Is the rear dimensions a tiny bit smaller? I have a sneaking suspicion one could stack the light and dark stock and cut the square with a slight bevel (a la marquetry) and presto-fito.
-Dean
Dick Coers
>I have used a chisel from a mortiser to chase square holes. No drill of course since they can nick outside the square. In something this fragile you would have to have the chisel very sharp, and go with a very light touch. I used this technique to inlay some mahogany into maple plywood, and it worked great.
very carefully....
Victor P
Ed Mulligan, Cape Cod
>My first thought was the banding that Warren describes. Fine Woodworking has run some articles on it and there is a succinct description of the the technique with drawings in Joyce. The spacing of the banding then defines the fretwork and the overall dimensions. Don't do it the other way (fretwork, then banding); you'll drive yourself nuts.
If you can closely inspect the piece and get some closeup shots it might confirm the banding theory, or not.
For strength, the fretwork gallery will be a 3-ply lamination with the center lamination grain running vertically. Even with the lamination, the fretwork is delicate. I had to repair a busted one once; what a headache!
more details
Bill Tindall, E.TN
>The light colored wood is inlayed into a solid mahogany side piece. I am quite sure the squares (actually they are rectangles) of satinwood? veneer are set into mating holes in the mahogany. So, someone has figured out how to make perfect holes and mating pieces to fit in them. There must be some trick to doing this that makes it doable by mortals. I would suppose that someone that does inlay or marquetry may know the trick.
This came out of the same shop (Headley) that made the French foot and there was for sure a trick to that.
Re: more details
>Well, I'm out of ideas :)
You're on the right track that however it was made the process was most likely not labor-intensive.
Marquetry requires sawing through the thickness of the work which contradicts the solid wood observation.
Inlay will be a fussy, labor-intensive process.
roninkokomo
>A guess
veneer laid over the solid wood and cut with knife and the wood beneath scored at the same time??
