Record Vise question
Bill Tindall, E.TN
>The jaws on my Record 53 vise are not parallel upon closing. When the left side just closes, the right side lacks 1/16" from meeting. It can be annoying at times and I would like to fix it if possible, but I don't know how. It would seem that if I could slide the right side forward on the rod the problem would be fixed but I have no idea how the jaw is fastened to the rod or whether it could be made to slip.
Re: Record Vise question
wilbur
>I'm not sure how you have your vise set up, but many people use wood to line the jaws of a Record style vise. You could adjust the thickness of the face of the wooden jaw liner so that the vise jaws are completely parallel when closed.
Richard Jones
>Mine is also like this, but I used whatever shims needed to make sure that the jaws closed up tight in both planes. Having the wood not be in 100% full contact with the face of the vice seems to make no difference whatsoever, and having them parallel has sure made a huge improvement over the way it was. Mine are Wiltons, not Records, but I assume the wood attachment would be the same.
Hope this helps.
Rich
Is it critical?
>Mine does, too - also the left side, interestingly; maybe it has something to do with the English driving on the left.
When I tighten up, play in the vise causes closing all the way across, and it seems to clamp wood just fine.
If, if it does bother, I agree that planing wooden inserts to counter the effect is probably better than trying to loosen, and then tighten, the movable jaw on the guide bars.
This gets me thinking about some of the American vises of this design that I have seen on which the guide bars are held on the movable jaw with large nuts, and whether these nuts were chosen, rather than other approaches, to allow for adjustment of the jaw fit; or whether it was just the most cost-effective method for that manufacturer.
Bill Tindall, E.TN
>Thanks....somehow I overlooked this obvious solution.
