Coupla considerations
Wiley Horne--So. Calif.
>Hi Stuart,
Congratulations on getting started!
Are you going to use the benchtop for glueups? Or will you have a separate assembly/gluing table? If the bench will be doubling as a glueup surface, then think about the width of things you might be gluing. For example, if you want to glue up a 24" wide panel, it is nice to be able to lay out 4 to 6 Bessey (or Jorgenson or Gros Stabil) clamps in a row, to form a bed for the gluing. But if the panel is to be 24" wide, then you'd be unhappy that the bench is not, say, 26" wide, so the feet on your clamps could sit on the bench. So think about your needs. Here's one metric: a 31" Bessey clamp, fully opened with 25-3/4" clamping capacity, can sit down on a 28" wide bench. None of this is a consideration if you're not clamping on the bench, but if you are give it some thought.
Another thing....different trades use different benches. A cabinetmakers bench is pretty narrow, for the reason Bill says. But what if you're sometimes a joiner and want to make an interior or even exterior door on your bench--24" would not be enough.
Wiley
