Re: Which raises a question...
Wiley Horne--So. Calif.
>Hi Glenn,
Here are the instructions printed on Old Brown Glue, from Patrick Edwards:
1. Glue viscosity is best at 80F. Never dilute. Warm bottle in sunlight or hot water bath.
2. Glue does not fill gaps. Wood work should fit right and be clamped properly.
3. ....Apply pressure for 12 hours. Complete bond is reached after 24 hours.
4. Clean up with cold water.
Ingredients: Hydrolyzed collagen and urea.
Wiley.......perhaps sunlight in a window to warm it up for use is different than storing in sunlight. Stephen's admonition makes sense from the standpoint that you want to store where it's cooler rather than warmer.
