OT - camp stove fuel as solvent
>We have almost a full gallon of Coleman stove fuel left over from our active camping days - probably more than a decade. I'm reluctant to think of either of the boys using it in a stove - I don't know if it goes bad like regular gas, but I assume so.
When I was young, this was called "white gas," to distinguish it from the leaded kind; and the old shop notes recommend gasoline often as a solvent.
Should I hold onto it for solvent purposes, or recycle it tomorrow at the hazmat site?
Re: OT - camp stove fuel as solvent
Dan Donaldson
>Not sure but isn't that stuff basically petroleum naptha?
msds for it *LINK*
Dan Donaldson
>Here is the msds. Looks like it is basically naptha.
coleman fuel msds
Glenn Madsen near San Francisco
>Smells the same. And works the same in camp stoves. I sent naptha with my son when they went camping last fall, and it worked just fine in the WhisperLite...
It's been maybe twenty years since my wife wanted to go camping. Now, it's Marriott quality, or she'll stay home.
Well, that's intimidating!
>Maybe I'll stick to mineral spirits as a cleaning solvent...
That's our case too
>We've both got funky backs, she more than I, and it's no longer fun waking up stiff and achy.
Chris Friesen
>Coleman fuel (aka "white gas" aka "naptha") is the best thing I've found to remove the residue from sticky labels.
Jack Guzman from Maine
not so fast
>That sounds like the Metholated spirits called for as part of a cleaning formula for old wood planes. Either Bugbear or Andrew posted it a few days back.---Jack
Bill Tindall, E.TN
>The material is naptha, chemically equivalent to mineral spirits but a bit lower boiling point(volatility). It would be fine to use in a camp stove or lantern if you ever have such a use for it. It would be fine to use instead of mineral spirits to clean brushes or thin paint. Or, you could pour it in your car while filling the tank with expensive CA gas. The above suggestions presume it was well sealed int the can. But if it was not it would have long since evaporated.
Jesper, Denmark
Re: Basically it is kerosine.......
Jesper, Denmark
>Mineral spirits or light naphtha.
It is OK as a solvent and cleaning fluid, zippo lighter fluid, lamp oil or grill starter.
ThomD
>Seams to kill ants on contact.
I had a Whisperlite near conflagration a few years back just kept getting a bigger and bigger fireball. Kinda scary because I was camped at a farm that had been loaned to a bunch of us for a timberframing project. Woulda sucked to have burned the place down. Can't recall how I got it under control.
Be careful
David Cockey
>"Naptha" is a somewhat general term refering to a wide variety of hydrocarbons. My experience with Coleman fluid is that it's pretty volitale and relatively easy to ignite. Mineral spirits is generally much less volitle and safer to use as a solvent. Personally I wouldn't use Coleman fluid as a solvent for cleaning purposes, but then I don't clean auto parts in gasoline. Others do.
Personally I'd find a safe way to dispose of it. Medical care for burns is expensive.
david schaefer fairbanks ak
>WHITE GAS ( bLAZO FUEL) IS UNLEADED GASOLINE...A NICE SOLVENT BUT EXPLOSIVE ...USE WITH EXTREME CAUTION.... I HAVE PERSONALLY SEEN THIS FUEL CAUSE MAJOR DAMAGE TO A PERSONS FACE '''TAKE EXTREME CARE IN ITS USE '''THANKS ds
Dan Donaldson
>Coleman fuel is not gasoline. The flash point for gasoline is a lot lower than coleman fuel. You need to take care with any flammable solvent, but the coleman fuel is not as dangerous as gasoline.
>Dan sorry to disagree.. it is unleaded...we used to get 40 gal a year that came in 5 gal square cans 2 cans to a wooden box (the boxes made the kitchen cabinets and other storage places)..highly flamable...I would not use as a cleaner unless in a well ventalated space take care...ds
Dan Donaldson
>It may be unleaded but it is not gasoline. Much higher flash point and less volitile. This does not mean that it cannot be a fire hazard, but if you look at the specs for it, it is basically naptha which many here use all of the time for finishes.
Not equivalent to gasoline
Bill Tindall, E.TN
>Unleaded gasoline is markedly different in many ways. Foremost, gasoline contains ingredients that boil at less than room temperature- butane and branched pentanes. Hence, the flash point of gasoline is way less than naptha. Were it not for these components you would not be able to start a car in the winter. Second, naptha is almost entirely aliphatic hydrocarbons. Unleaded gasoline contains a substantial amount of aromatic hydrocarbons. As such, it is a way better solvent than naptha.
What may be confusing is that back in the days before Coleman fuel was available everywhere, some people used Amoco premium gasoline for stove fuel.
