We value your privacy.
>I posted this on the general message board, but figured some folks here may not read that board often, so I am repeating here.
I am an absolutely new carver. I have a set of carving tools (Swiss Made Rockler Anniversary Set) plus 4 other (Ashley Isles) that need sharpening. These are new, so the factory bevel is still on them for guidance. What I don't know is how to sharpen them properly.
I went with a friend to a carving studio one night and saw that they had a couple of wheels mounted on a motor/arbor setup. One wheel looked to be linen, the other leather. I assume both had some sort of compound on them, as it took just a touch to bring a sharp edge back to the tool.
I have a 6" grinder I am not using. Would it be appropriate to set this up with 2 wheels dedicated to sharpening carving tools? If so, what wheels/compounds, etc. do I need? Am I even on the right track here?
>I use Arkansas bench stones and slip stones and a clean leather strop to sharpen my gouges. It takes me 25 or 30 seconds to sharpen a gouge. I have never touched a carving tool to a grinder. There are two methods of sharpening a gouge. One way is to have a bevel of 25 or 30 degrees and to work the inside with the slip stone flat in the flute. The other is to have a longer shallower bevel, 15 to 20 degrees, and put a second bevel on the inside with the slip stones. The two methods give the carver slightly different angles of attack. The first acts a little more like a bent or spoon gouge and the second acts a little more like a back bent gouge.
My feeling is that someone who uses a grinder and buffing wheel is not very particular about the edge they are getting. But of course an experienced worker with a grinder might get better results than a beginner with any method.
>Sharpening carving tools can be tricky, due to the complex shape of some blades, and the requirment for a very good edge - you can't use a belt sander to clean up the finish on a carving.
For this reason almost any carving book will have a large section on sharpening methods.
I'd head for a library before you head for your credit card.
I like Bugbear's advice. However, I'm a little surprised about one thing. I have received a few Pfeil (Swiss Made) gouges, and without exception they were sharp from the factory. They also have that reputation, so I think others have had the same experience. And I think I know what sharp is. Now this was a few years ago, and i think I bought them from Woodcraft.
If you take one of your Pfeil's, will it slice into the edge of a page of the morning newspaper, the paper being held at right angles to the tool? If you lightly strop it, will it do it? Mine arrived in that condition, is why I ask.
