Mortise chopping: from the middle out, or
wilbur
>I've been on a run of chopping some large (for me) mortises. These are about 1" wide, 3 1/2" long, and 2 1/8" deep, and I'm using a 1" mortise chisel to make them.
There seems to be two methods of mortise chopping. Many sources I've seen seem to advocate chopping out a V in the middle, and working out towards the ends. The bevel of the mortise chisel faces the ends. When the V is cut to depth, the chisel is reversed so that the flat side faces the ends, and the rest of the mortise is chopped that way.
One disadvantage I've found is that my mortise chisel seems to be a little asymmetric, so that when I reverse the chisel when going from one side of the V to the other, there will be a little unevenness in the wall of the mortise. I know that I can pare the sides of the mortise, but I always thought that it was best to avoid paring the sidewalls of the mortise whenever possible.
On the other hand, other sources, including Frank Klausz, suggest chopping a mortise starting at one end, and working across the length of the mortise. I actually find this to be easier in terms of keeping the walls of the mortise straight.
What do you all do?
