Re: sapstain and drying your own wood
Dave Mount
>Yes, sapstain will definitely happen up here in MN too. Red pine is worse than white, but both will stain easily -- both the grey/blue and the brown varieties. In the case of this batch, I should have known better. I stacked and stripped it immediately off the saw on a flatbed, for the express purpose of getting it out for some quick air. Putting pine out in the open air and breeze is usually enough to keep the stain away, same for maple. However, we had a couple rainy days after sawing and I parked the load in the barn, then didn't get it out again right away. Even though it was on sticks and out of the weather, the damp air and lack of air movement (not much air moving in the barn) got the sapstain going. Fortunately, the stain is limited to the sapwood and the heartwood is unaffected. Since I only had about 20 cents a bf into it, it's no catastrophe.
Years ago we sawed a couple thousand feet of white pine and treated it with fungicide. That was very effective, but it was a pain going through the whole pile board by board and spraying all four sides. The fungicide was not exactly cheap, but it kept the wood very bright.
Despite this tale of mini-woe, I don't like to discourage people from drying their own wood. Yes, you can damage some wood if you screw up, but most of those mistakes can be avoided by reading a lot on the topic and getting advice from those that have done it. But I agree with your basic tenet, that there is a little more to it than just throwing planks on sticks. In my case, with a sawmill in the family, my mistakes are cheap.
If anyone is interested in getting into drying their own wood, I'd strongly suggest walnut. I never dealt with a more forgiving wood to dry. I've dried pieces of walnut that had the pith angling through the middle of the board (i.e., pith was one one side of the board and one end, passed through the middle and was on the other side of the board at the other end). If that was cherry, it would have been a cracked pretzel when dry. The walnut dried straight and didn't check, even where the pith went through. Not that you won't ever get pith checks in walnut, but it is very forgiving. Walnut sapwood can stain a little if you abuse it, but the heartwood won't. Thick oak on the other hand. . .not so easy.
Anyway, my point is that Bill's cautions about the consequences of improper drying shouldn't be ignored, but I wouldn't want that to discourage someone that's inclined to try it. Like most things, it's not hard once you are armed with a little knowledge.
Best,
Dave
