We value your privacy.
I found a piece of 1" dia x 4" long brass stock and have decided to make a plane adjusting hammer out of it. I used the milling machine at work to drill a hole for a handle that is dead center of the brass stock. But after some consideration, I think it's a bit big for a plane hammer. I calculated that it weighs just about 1 lb (0.9927 lbs to be exact!).
Do you think that's a bit heavy for adjusting wooden planes? I looked around online and came up with some articles on making a plane adjusting hammer. Most of them are about 1/2 to 2/3 the weight of the one I have. Before I trim some off each end, I wanted to ask those more experienced with wooden planes what they thought.
>That seems quite heave to me. It depends a bit on the size of the plane. If the plane is a wooden jointer that is 36" long and 2" or so wide, then you are going to need a larger hammer than for a small coffin smoother. I would guess that the hammer I use most is in the 4-6 ounce range. I made it, so never did weigh it, but it definitely is less than a pound.
Dave Anderson's hammer (Chester Tool Works) is about perfect to my hand. I think it is approx. 8 oz head weight and 10 oz total weight, but that is going from ancient memory, so maybe someone knows for sure.
What you want to do (IMO of course) is have a brass poll on one end, to strike the blade, and then have something else for the opposite poll. Could be wood, or urethane, or hard rubber. The brass poll is good for tapping the blade in and catching the sneck on snecked irons; and the softer end is good for hitting the stock to back out the blade and/or wedge.
Think about a brass poll at one end, then abbreviate and drill a hollow in the brass at the other end to hold the softer poll.
I use a wooden mallet for adjusting the blades on my Japanese planes. It's just about 6 oz. I also use it for backing out the blade. I have a 14 oz. mallet for when the blade gets stubborn about backing out.
I also have a metal plane adjusting hammer that's 115 g, which my unit converter tells me is about 4 ounces. I rarely use it, but I think that's more because that it's made of metal, not wood.
>I think the consensus is that a 1lb hammer may be "a bit much". So I'm going to cut it a bit shorter and weigh about half what it is now. I'm also going to add a wooden face to one side. That shouldn't be too hard. I just need a suitable piece of end grain hardwood. I'll turn a tenon on one side of the brass and glue that into a hole on the hardwood "plug".
Actually, that's exactly what the hammer tutorial I was following suggested. So I went the long way around to end up back at the beginning!
Brass is gentle on steel blades. Not so good for the back of woodies. However, having used wooden mallets for years, I now prefer the rapid feedback one gets from metal over the softer response from wood.
I will also add a recommendation of Dave Anderson's Chester Toolworks plane hammer. The brass head is rated at 8 oz and a one Lignum Vitae face on the other side. This is a very nicely balanced plane hammer, and you could do worse than to use it as a reference.
While I was waiting for my order to arrive I had a rush of blood to the head (this does happen too often!), and decided to make a plane hammer anyway. I had come across an eBay seller offering brass mallets for jewellers. I could see a way to modifying and using the head. It only cost $5.
I chose to make one a little lighter, with a 7 oz head, and a shorter handle. The balance is good because the head is small (I really should weight it since it looks so much smaller than Dave's). The plane adjusting side is leather-faced.
Dave's is the lower one ...
Dave's hammer is great for larger planes, while I prefer mine for smaller ones.
My head weighed in at almost exactly five ounces. I made it out of bronze and the handle out of hickory. I used dogwood for my striking face. It works beautifully on a little smoother. I haven't had the opportunity to use it on a big plane. I have used it to strike a chisel or two and it has done very well. I posted the details a couple of weeks ago.
>I use an 8 ounce hammer, but there isn't any absolute number since it depends on your plane and how you set it up. A light hammer that does a lot of arty tapping is pretty useless if you can't get the blade set efficiently. I hate the looks of the hammer i most use, it has a plastic handle a chromed handle and a plastic head, but it gives the best feel of any hammer I have used. I bought it for reloading where it wasn't supposed to mar some tool. Been using it a long time. I don't care for brass hammers all that much though it sounds like a fun project.
Good point! And ? about grain orient. on wood plug
Dominic in Bucks County PA
>Phil,
I was thinking about that just the other day. The only thing I'd be worried about was dropping the hammer by accident and the wood shearing off in the hole.
As far as forming a tenon on the brass and drilling the wooden plug, I wasn't going to drill a very deep hole. Probably just 1/4" dia. And the wooden plug was going to be at least 3/4" thick. Like the article I'm following, this would be epoxied in place.
Now the question begs, what grain orientation for the plug? :>) I'm thinking that end grain (like any wooden mallet) would be the eay to go.
I put the tenon on the wood part and the 'mortise' on the metal head. I just press fit the parts together -- no glue. The mortise and tenon are both about 1/2" long. I oriented the wood so the end grain was the striking surface. It ended up being well balanced.
