Veritas - Innovation in Tools
Anyone seen one like this?
Stuart Hough
>Won it on the 'bay. Has a curious way of connectiong handle to blade. Looks nice, only a smal "wave " to the blade. Will try to have it cleaned up and straightened for use for DT's on a future project. Thanx for any and all info.
Re: Anyone seen one like this?
Re: Anyone seen one like this? Pic #2
Stuart Hough
Re: Anyone seen one like this? Pic #3
Stuart Hough
Re: Anyone seen one like this? Pic #4
Stuart Hough
>Handle looks very nicely contoured. Looks comfortable.
Wiley Horne--So. Calif.
>Stuart,
To answer your question, no. It looks to me like a user modification or possibly an outright replacement. Looks like a sound job, though.
Wiley....waiting for Marv or Todd to provide the right answer.
Re: Anyone seen one like this? *LINK*
Marv....... Northern California Lake Co.
>Hi Stuart,
From your pictures, the saw looks to have been homemade from end to end. You didn't indicate any maker name or marks.
If the blade is only slightly bent, say, 1/32" bow for example, I wouldn't do much to straighten it unless it easily returns to straight with little effort. Sometimes you can make it worse. It will cut a straight dovetail even with a small wow to it.
If the back is straight and the blade isn't, that means there is uneven pressure on the blade inside the back. Often times you can straighten the blade by merely removing the back and then gently tapping it back on. But before you do anything, sharpen it first, do some dovetails and see how well it cuts.
I noticed there is a small crack in front of the front screw on the left side. I fix those kind of cracks by removing the handle, saw out the crack and glue in a thin piece of new wood.
Below is a link to some before and after pictures of a handle that had some major cracks. The saw is an Atkins floor saw.
Marv
Crack repairs in a saw handle
Stuart Hough
>Marv, there are no maker's marks that I can find. Also looks to be no etch. The "wow" is at the teeth. when sighting along the tooth-line, you can see what almost looks like a buckling over of the teeth. It's not severe at all, just looks like maybe the saw was dropped on the floor, and hit on the teeh close to the handle. As for the size of the saw, it's blade is approx 4-4.5 in. long, and the handle is very small, almost like it would ft a 3 year-old's hand. i haven't gotten around to accurately measuring it yet, but it looks really old. Maybe you could work your magic on it if you have time.
Victor Parisian
>Wow, Marv that is truly a labor of love. Nice photo documentation. I wish you had a picture of the handle in it's original cracked state, though I can imagine it.
Thanks again for sharing.
Victor
Exceptional work, Marv!!
>Marv,
That is a very helpful sequence of photos, and a beautiful result. I think one of the keys to it is the way you have oriented the patches--the patches are angled to show face grain against face grain and end grain against end grain.
Thanks for showing,
WIley
