tapering a blind hole for a leg tenon
Bill Tindall, E.TN
>To review.....I took a class that involved making a short three legged stool. I thought the design was flawed because the leg tenons were not tapered. To try to fix this deficiency I did not fit the tenons in class and then asked the sages of WC how to taper a blind hole such that I could then taper the tenons and wind up with a leg that would tighten with use. Among the more practical suggestions was one to make a taper cutter. I am not sure I executed this suggestion correctly but what I wound up with worked.
I cut a tapered plug with a stem for turning it. A slot was cut in the taper with a dovetail saw and a section of fine toothed hacksaw blade was inserted. The problem to be solved was how to turn it. There was too much resistance where it crossed the end grain to turn it by hand. Various hand powered attempts at turning resulted in the cutter binding, again at the end grain, and splitting the devise as show in the PIC. Fortunately these tapered plugs were easy to fabricate on the lathe. The fourth and final attempt was made using dense maple, with a short stem and very small blade projection, all key elements. It turned out that turning it fast with a power drill was the secret to success. It took but seconds to achieve the taper. I tried smoothing the taper with sandpaper wound around the plug and this operation smoothed the taper.
The picture shows the bottom of the stool with two legs dry fitted as well as a broken plug, the successful plug with the hacksaw blade (red) inserted and the sanding plug.
Thanks to who it was that suggested making this cutter.
Re: tapering a blind hole for a leg tenon
So?!
Scott in Douglassville, PA
>Where's the pic of the assembled stool?!
Nice tapered reamer. Good job.
Wiley Horne--So. Calif.
>Hi Bill,
Amazing! That hole looks as clean as if it were done with a Forstner or sawtooth bit! Did you just leave the hacksaw teeth as you found them?
Also, how deep a hole is needed for this operation? In other words, how thick of a seat blank do you need to start with?
Thanks, Wiley
Philip F Duffy
>Have you tried using a spade bit that you grind to a taper that you then match on the leg? I have seen people grind spade bits for similar purposes. Phil
Bill Tindall, E.TN
>Not knowing what to do I just left the teeth as they were (it was a sharp blade). Seemed to work that way.
The seat is turned from 8/4 maple with the hole 1 1/4" deep.
reply
Bill Tindall, E.TN
>That may have been a good way to drill the original hole but the straight holes were drilled in class and I didn't have the option of trying what you suggest. As far as tapering the hole after it was drilled straight I think the spade bit alone would have chattered excessively but it would be worth a try. Maybe the tapered spade bit in a brace would be the trick. The hacksaw plug in a brace wasn't; the shaft part promptly snapped when it hung in the end grain fibers.
ThomD
>If you do that it isn't a reamer, it may drill a hole, but you have to have the normally very long spur engaged or it won't center. The saw type reamer which in different form John Alexander discovered or promotes will smoothly enlarge an already drilled hole.
ThomD
>One other thing. When Alexander tried the original version it was a tapered key hole saw, and the blade protruded on both sides of the tool, with the back of th saw sharpened like a scraper. It was the scraper side that was intended to do the work and they just left the sharp teeth in the hopes they wouldn't do any harm. The combination is relatively magic and cuts very well, or apparently here with only the saw teeth.
how?
Bill Tindall, E.TN
>You said the hole saw protruded both sides of the tool, which in principal would be a superior arrangement for cutting However, I am not seeing how that arrangement would be possible. I split 3 of the wooden plugs with the blade embedded only 1/2 way. Had I cut a through slot to accommodate the blade sticking out each side the wood holder part would have had even less strength. Maybe I don't understand how the original was made.
Re: how? *LINK*
Larry Barrett
>Below is a link to the John Alexander plans for a tapered reamer. I have made and used this reamer on chairs and it works well. I found that the saw teeth acted like screw threads, even though the sharp side shaved off most of the threads; the taper was fine, but the reamer was hard to extract because of the "threads". I made another, filing off the saw teeth, and it worked better, in my opinion.
Alexander Tapered Reamer
Aha! I see the flaw in my reamer
Bill Tindall, E.TN
>My reamers twisted off where the taper transitioned to the smaller spigot. This reamer doesn't neck down, there-by strengthening this stress pint.
Thanks.
PS, question
Bill Tindall, E.TN
>Have you used it on dry wood?
Re: PS, question
Larry Barrett
>Yes, on dry (at least, air dry) and green wood. When first inserted in the drilled hole, the reamer is touching the hole only where the reamer diameter matches the hole diameter. So when you start to turn the reamer, the part of the reamer below this spot wants to twist and open violently since the hole is not yet constraining it, and the part of the reamer above the hole also twists a lot, to the point where you are sure it will break. This all is mitigated as the reamer starts to work and more and more is supported within the reamed hole. I made my reamers from tough wood - ash and hickory - and neither has broken (yet). But both have a permanent twist in the body of the reamer and in the saw blade as a consequence of this twisting, though it doesn't seem to affect anything.
