What A Find! *LINK*
What A Find! *LINK*
What A Find! *LINK*
Bob Henderson
>I took a load to the dump today. The dumpster was almost full and sitting on top of the pile was this Old Disston saw. Needless to say, I grabbed it.
From what I could glean online, the handle is designed for a cross-cut saw, but the 28" blade is toothed for ripping. The bolts & nuts look like they have been filed down flush with the handle at one time, so maybe the owner replaced the handle with one he had kicking around and the nuts didn't seat to his satisfaction. It has the little nib on the front of the blade and a hole in the tip of the blade. The blade is covered with rust, so the etching is barely visible in parts.
Any further information anyone can provide about this saw would be appreciated.
The handle is sound and the blade is straight, so I'd like to restore this saw as a user. Can I remove the rust electolytically without destroying the etching (or has the rust already destroyed it?).
More Pictures
Re: What A Find! *LINK*
Re: What A Find!
Patrick Gibbons, Katy, TX
>Rust is not a problem. Does it have many pits? The handle looks original to me. Most rip saws' handles were indistinguishable from crosscut saws. The hole is a user modification designed to facilitate storage; in other words, a hang hole. I'd clean it up with WD40 or mineral spirits and 220 grit paper. I have never lost an etch doing this. Consult Pete Taran's site which can be accessed through links from this site on a complete tutorial. Also check the archives as this subject has been kicked around a bit here. If it does have a lot of pits than it's better suited to being a rip saw. Too many pits and it's probably not worth the effort though I would keep the handle and nuts and maybe use the blade for scraper material, etc, etc. HELLO! DID YOU DIG INTO THE DUMPSTER TO SEE WHAT ELSE MAY HAVE BEEN THROWN AWAY?
No information, but
>that's a nice looking saw. A little cleanup, and it'll be ready to rip. So to speak.
Re: What A Find!
Marv....... Northern California Lake Co.
>Hi Bob,
Indeed, a very nice find. Your saw is a very early Disston No.7 or it could be a No.8. The No.8 is exactly the same as the No.7, but has an Applewood handle. All No.7,s have Beechwood handles.
The flush screw heads are original. That's the way they made them during that era. I'll guess that your saw was made during the 1850,s or 60,s based on the flush screws and the sunken medallion.
Try not to remove the handle when you restore it. The screw nuts might not have ever been moved to tighten. You can tell by looking at the sanding lines in the brass. If the lines on each screw nut are pointing in the same direction, they will probably not have been turned. I have a saw very similar to yours with screws that haven't been turned.
To clean the blade, I would cautiously sand it with the use of Mineral Spirits, but avoid getting any on the handle. Don't try to make the blade shiney, just get it smooth and sand off as much rust as possible and expose the etch. The etch with show the No.7 or No.8. A No.8 is even more rare than the No.7.
The handle is designed with a larger grip hole that allows for a thumb to fit through at the top. The handle is in fact made for two handed rip sawing. It's actually a more comfortable handle to use for ripping compared to the Disston D8 with the thumbhole and it is designed for both left and right handed people, where as the D8 isn't. The D8 is not to be confused with the No.8.
Because it is a 28" blade, it is probably an original rip saw.
A good cleaning solution for the handle is Kramers Antique Improver. It will not effect the old original finish other than to improve it. Google the name and you'll find the website. Try this http://www.kramerize.com/
Electrolosis will remove the rust, but it will leave the surface of the metal a gray matt color that is, IMO, unnatural for an old saw like that. Most of the time when an old saw is thoroughly rusted like that, there will be a very dark discoloration just beneath the rust. That dark surface can be made very smooth and will retain the age of the saw. In other words, it will still look old and most of the time, the etch is still legible. When sanding in the etch area, use a sanding block. with the blade laying on a flat surface.
You will hear from people with all kinds of methods used to clean a saw. It's pretty much a personal preference as to what you like to see with your collectible tool. I like what Mike Stemple told me not long ago..."we are only temporary custodians of these old gems, until they are passed on to the next custodian".
Marv
Re: What A Find!
>Your handle appears to be beech and I would guess it's a #7 also. Go check the Disstonian Institute site to date your saw by the emblem on the nut.
Re: What A Find!
steve mackay
>#220 has always worked for me too. Then polish with steelwool. Then Johnson's. Honestly if the etching is still there, it is. If it ain't . . . it just ain't. : )
Re: What A Find!
Todd Hughes
>I think as others have said that it is a No. 7 , this was the most common saw that Disston made and is thier original saw. You can look up the saws medalion on the Disstonian page to see when it was made.
The older Disston saws were stamped in small letters and not etched, if etched I think the saw is probably from the 1870s.I recently sold a simular one that had one of these early etches. A person emailed me who sounded like he knew what he was talking about and said it was actually stamped and not etched and was a rare saw because of it's markings...I had my doubts. If rare it still didn't sell for much on the ebay...
I didn't get mine for free though...had to pay $2!.....Todd
Re: What A Find!
>Hi Todd,
I see lots of No.7,s on Da-Bay. For some reason, they aren't very popular. They either sell for very little or not at all. The No.7 was one of Disston's better sellers, but I think the D8 and the D23 were their best sellers.
I have a No.7 listed this week. It's doing better in less than 3 days than I expected. Sure wish I knew where to buy them for only 2 bucks.
I noticed you have a couple nice looking backsaws up this week. Don't tell me how much you paid for them. *grin*
Marv
Todd Hughes
>Ebay is pretty hot right now with some of the highest prices on some things that I have seen in a long time, saws seem to be doing very well and I have to get some listed.
Heres a rusty one with two broken teeth I just sold the other day for over $200 which I found very surprising.
To say I have lots of saws to sell is an understatment but they can be a pain to clean up and to sell so they always seem to get put on the back burner in favor of easier junk to sell.
... Because in the wild saws sell so cheap it's hard for me not to spend a couple bucks and pick them up, the Disston 99 I got for less then a $1 [ bought 3 saws for $2 at auction]....and then pretty soon you have 5 foot tall piles of them setting around .....Todd
Disston No. 99
Re: What A Find!
>The Disston No.99 is one of the most collectible saws they made. I saw one sell on Da-Bay about two years ago for just under $400. It had a broken upper horn. It was restored by another saw restorer, another guy who sells on eBay.
The saw you sold was in great condition. I'm surprised it didn't sell for more. You must live in old saw heaven. All the cheap good stuff seems to be on your side of the Mississippi.
Marv
Re: What A Find!
Todd O. Cronkhite Maine Native Presently Away
>Todd fails to mention that his 5 foot high pile of saws is 30 feet wide. :~O
