Re: Elegant solution
Dave Mount
>At only 10" wide I'm not sure this approach is worth the effort for your carcase, but a few years ago in FWW Chris Becksvoort did an article on using sliding dovetail cleats to attach cross-grain moldings. As I recall, the process was to create a dovetail groove in the back of the molding, then make a mating strip of wood, trapezoidal in cross section, that completely fills the groove in the molding, but no more than that (like a dovetail key). The trapezoidal strip is located onto the carcase in the appropriate position, basically making the carcase into the male portion of the sliding dovetail. Obviously, if left like this, it doesn't really solve the cross grain problem.
The trick was that while the dovetail key was still one whole strip, it was screwed, not glued to the carcase. Then the strip was removed, and sections of the strip were cut away, leaving only short, dovetailed blocks (obviously the screw positions were planned so that screw holes were in the parts that would be retained). These blocks were then remounted to the carcase, and their positions automatically align because the screw holes were drilled when the dovetail key was still one whole strip. The molding is then slid onto the carcase and mitered to fit. After fitting, the molding can be glued at the miter and the front key, allowing the movement to be taken up at the back of the carcase. Because the male part of the dovetail is broken up into sections, it doesn't cause a cross grain problem.
Like I said, it may be more fuss than you want to go to for a relatively narrow carcase, but I thought it was a really clever solution to the cross-grain molding problem.
Best,
Dave
