Need help veneering
Need help veneering
Joe McMahon
Need help veneering
Joe McMahon
>I have never veneered before. I have a piece of veneer with an inlay on (in?) it. The veneer is QSWO and measures 55" X 5" the inlay is centered, 8' down from the top. I want to glue it to a piece of QSWO that I am using for a door style. The style will be 2 1/2" X 50" and I want the inlay 8" down from the top. (I am actually doing two of these- both styles)
Do I cut the veneer before I glue it to the style or glue it & then cut it. How do I cut it? Do I place the veneer on a flat surface and put the receiving board over it & use a razor knife to trim both sides & the end? Won't this leave a ragged edge?
TIA, Joe
Re: Need help veneering
Bill Tindall, E.TN
>I don't understand the 2 1/2" substrate and the 5" piece of veneer so this answer may not be relevant to your task at hand. In general if I was veneering a 2 1/2 " substrate I would cut (with Exacto knife or equivalent) the veneer strip a bit wider, say 2 5/8, apply glue, fasten veneer down with blue painter tape along the edges, and slap it into the clamps or vac. bag. After adhesive cure pull tape perpendicular to veneer grain to keep from lifting veneer grain. Trim veneer to sides of substrate with a hand plane.
And I would be concerned that the water from the glue would make my 58" x 2 1/2" piece something less than straight and flat.
