We value your privacy.
>I have some rosewood that I have put together with maple and ebony on the top edges. I saw a set of winding sticks that were dovetailed on the ends with the tail on opposite ends so as to lock together when not in use. Can anyone tell me how to add a dovetail on each end so as to lock them together?
>The ones I have were made by Jim Bleauvelt (SP) a japanese tool user of very high skill. None the less, each piece had a little dovetail router plunge at each end, down and sideways so that there was a hole straight in with a dovetail recess to each side. Jim made up a bunch of dovetail key strips that were split off into individual pieces, presumably these were also routed.
You have to square out each hole so that the key can go down through the hole and be moved sideways. And square out the end of the slot so that the key is in full contact when it comes to the end of the slot. A bit like deciding to square up the tenon or the mortise when workng with router mortise and tenons.
>I, too, saw something similar in a Japanese tools class. The DT key allowed him to store the sticks together, and also to plane them together, since he also used them as straight edges to check his plane soles for flatness. To check the sticks for straightness, he simply held them up, (intended) straight edges against each other, then flipping one of them 180 and checking again.
Useful things, those sticks. And here, years later, I'd all but forgotten about them... thanks for the reminder.
