I have a type one LN, Neener, Neener
Neal in San Jose
>A couple of month's ago I posted about a problem I was having with my old LN low angle block plane with the blade adjustment nut hitting the base casting (the numbers, actually), limiting the blade extension. I've sharpened the blade over the years to the point I can no longer extend it far enough to take a shaving! (I also teach classes on hand plane use for beginners, so sharpening out nicks in the blade isn't unknown to me.) No one on the board said that they had the same problem, and I sent LN an email about the issue. They responded that they hadn't heard of this happening, and to send them the plane.
I finally got around to sending it to them, and Deneb said that they actually had run across this, and had changed the design slightly to raise the adjustment rod. They were going to replace the blade with a new, full length blade and tweak the adjuster rod up so that I would have more adjustment. Well, they didn't replace the blade, but they did bend the rod up slightly so that it works again. I guess all's well that ends well.
I think I'll put this plane in a safety deposit box. No doubt some collector is going to offer me a gazillion dollars for it sometime soon!!!
