Coffin smoother wedge rebuild update
Dominic in Buck's County PA
>Hi gang,
I finally got a chance to mess with that wedge I made for my old wooden coffin smoother. I used walnut for the new wedge and followed the directions I found at the Norse Woodsmith site. Side note here: That is one hell of a site! It is just chocked full of great information!
I'm glad I let this sit for a while before I went at it again. After making (2) wedges and not having either work I figured it was a good thing to leave it alone for a bit. As it stood, one of the wedges wasn't as bad as I had thought. So all it took was some careful chisel & rasp work.
It turned out that the abutments are not quite at the same angle. So I had to tweak the wedge a good deal to make it fit perfectly. Before this I used a belt sander to narrow the sides of the iron by a hair, and flattened/polished the chip breaker. But it was getting the wedge to fit right that did the trick.
Here's some shots of the smoother after trying it out on a piece of cherry.
Photobucket
Photobucket
After I was confident that I had the wedge sized correctly, I cleaned up the corners and used a rasp to steepen the incline on the inner "ramp". After all the work I did making sure they fit, I left all the sections that contacted the abutments alone!
Here's a shot after I tried the smoother on some ash.
Photobucket
The next think I'm going to do is either laminate a new sole onto this plane, or just install a insert at the mouth. Either way, I have a nice piece of pear that will work.
BTW, I was examining the front of the plane this afternoon and noticed the maker's mark. It's partially worn away but I could see a star and some letters. Anyone know of a plane maker that uses a star in their logo?
See ya around,
Dominic
Re: Coffin smoother wedge rebuild update
Wiley Horne--So. Calif.
>Hi Dom,
Great work! Makers who used a star:
Auburn Tool Co. (in a semi circle)
[star]
Auburn, N. Y. (straight line)
D. R. Barton (in a semicircle)
[star]
Rochester, N. Y.
{all of the above inside a half-moon cartouche}
The Birmingham
CONN
Plane Mfg Co.
[star]
W. O. Hickok
[star[
Harrisburg
{Hickok and Harrisburg arranged in a circle around the star}
J. T. Jones,
Philada
{many different logos and abbrevs. for Philadelphia--most with a star}
William Ward and also Ward & Fletcher, New York used a unique 4-pointed star
Wiley
Peter Evans
>If a star and a crescent on the mark, then Mathieson - they made millions of planes
Jim Shaver - Oakville, Ont
>Lovely work Dom...
Take care,
Jim
wilbur
>Glad to see that you got it up and running! Now you'll have a whole new set of planes to start rehabbing. You might have to unload some of those cast iron models that are going to be in the way. :@)
Dominic in Bucks County PA
Not bloody likely!
>Wilbur,
You wrote:
"You might have to unload some of those cast iron models that are going to be in the way.
LOL! Yeah,....like THAT'S gonna' happen! :>)
Why not keep both around? It's just that I built this big tool cabinet so that ALL my planes could live in peace and harmony. There's room enough for some of each....!
Later,
Dominic
I don't know Dom...
Scott Burr in Ben Lomond, CA
>I've heard they don't play well together. Iron ones want to play ON the wood ones. Not Pretty...
Nice atomic wedgie you made by the way, glad you didn't wedgie me!
