Homemade Marking and Cutting Gauges
L. Hanson
>Ever have one of those moments where you realize you've been using a tool for so long that you don't actually realize just how worn out it is? I have had this old Stanley #77 marking gauge for a very long time, and I was having trouble with it. Looking at it, I realized that not only had I filed the pins to the point they were really just nubs, but also that the face of the thing had worn to where if you didn't use it at a certain angle, your line could vary by up more than 1/32". Even the brass in the face has worn...
I imagine I'll fix it back up someday. I thought about ordering a new one along with a cutting gauge I need for my current project - but then remembered a wonderful old piece of perfectly quartersawn cocobolo I had in the stash. Plus I had all this brass laying around - so off I went:
The two cutting gauges are based on Steve Latta's design and use Xacto #19 blades. The other three are traditionally designed - the two mortise gauges each have three pins (one underneath), with one made from 1/8" drill rod I hardened myself, and the other I used 1/16" drill bits for pin material. I even made one so the other end will hold a pencil...
The last, another cutting gauge, uses a blade I fabricated from a used-up lunchbox planer blade.
More on the gauges here if you're interested. Lots of fun to make! I should be covered for a while, now... ;-)
