Plywood expansion
Plywood expansion
Plywood expansion
David Miller from Iowa
>I'm making some good size cabinet doors - 30" wide x 40" tall. Will use pocket screws on the frame (lets not debate this part, I am aware M&T is stronger) and 1/4" plywood inserted into dados on the frame.
2 questions -
How deep should I make the dado?
Does plywood expand to the point where I shouldn't glue the panels in? I'm concerned about sag with a door this size if I let the panels float.
Thanks
Re: Plywood expansion
R.J. Whelan
>David ... I have had one experience where some 3/4" birch veneer (30" wide) expanded about 1/4", seasonally.
I usually make door panel dados 1/2" deep (for solid wood panels) and then cut the panel 1/2" undersized which leaves 1/4" room for expansion to each side of center. I pin the center of the panel to the frame to hold it in position and then install 3-4 1/4" spacer balls in the dado (available from Rockler).
I don't think I'd be overly concerned with sag on your doors. If you make the frame fairly robust (stiles 2" minimum and rails 3" minimum) and install 3 pocket screws at each joint you will have a pretty rigid assembly. The weight of the plywood panel will be fairly insignificant, unless you are using MDF core. I would not glue the panels into the frame.
Good luck with your project ... rj
Somewhere in between
Ellis Walentine, Host
>Plywood does expand slightly, although even the lowest grades of exterior ply only ask you to allow 1/8" of space between adjacent sheets when you're laying them down as roof decking, etc. Cabinet plywood should expand only negligibly over 30" or 40", in my opinion within the range of flexibility of yellow glue, so I would not feel obliged to leave more than just a tiny bit of wiggle room in the grooves.
Regarding sagging, that is something that a frame does because of gravity over time. It is more likely in cases such as yours where you are relying on steel fasteners to hold butt joints together. A M&T, as you suggested, would be more rigid. The good news, though, is that your plywood itself is your insurance against sagging. Regardless of whether the frame members are substantial or just thin edging strips, as long as they are attached to the plywood, with glue or pins or whatever, they won't sag.
ThomD
>Good question, I don't know the answer, it would depend on specifics, particularly your local/in house climate. I did make some kitchen cabinets once in the deep dark past that consisted of two stiles on the side, and a plywood panel mounted in the grooves in the stile. The surface was scored in a geometric pattern, not my design. That worked because the frame didn't encircle the panel, but it probably would have worked if the panel had been encircled since plywood moves very little at all. It's movement is more in the order of swelling, and that requires a fair amount of moisture. Many kitchen cabinet use glued-in ply panels and those coped corner joints right off the router that do not have much MT type engagement. But even there there is the minute movement in rails and styles themselves to deal with.
The whole point to frame and panel is that you can eliminate the guesswork, by floating the panel. Pocket screws, while cheap looking, have the reputation of being very strong, so I would not hesitate to use them in an actual panel construction. Another option that is just as fast are biscuits. They probably won't last out the centuries, but are very strong for as long as the glue joint lasts. The main failure mode is the break it over your knee type mode, not the hanging from the hinge mode.
When working out of the reach of decent materials, I have made some very handsome doors from mahogany jam sets for the frames, and bead board for the panels.
