Re: A couple comments, Richard
Sgian Dubh
>Ellis, I forgot to include a description for testing the need for flattening which I sometimes use which is similar yours, ie, the squashing the veneer between a couple of flat surfaces. I've used everything from a workbench top to a table saw and laid a piece of ply or MDF over the veeneer. Crunching noises, ripping and snapping noises, as you say, are a giveaway.
The 'concentrated' glue mixture you referred to isn't that concentrated really. It's only 2/7ths or about 28% glue. The mix, once the veneer is flat and dry, seems to hold veneers flat in most cases for quite some time. It's not a perfect cure for severely rippled veneer, but it seems to work I'd guess about 80- 85% of the time. I can't recall having problems with sticking the veneer after the treatment due to the presence of PVA glue.
You mentioned the use of hide glue instead of PVA. I've also used this, but in my case it's always been the hot hide glue. I've used about the same 2/7th proportion as the PVA mix I described. This works too, but it's often the case that this type of glue isn't handy in our workshop, so the convenience, ubiquity, and ready availability of a tube of PVA comes into play here.
Nor do I recall particular finishing problems due to the presence of the glue. I quite often use PVA glue to stick down veneer anyway, and some woods, particularly open pored ones get glue bleed through leading to localised gobs of glue showing on the top surface. In this case I usually go over the whole surface with a PVA glue wash at about a 3 glue to 7 water split, let it dry and then scrape and/or sand the surface ready for polishing. This seems to just about eliminate any tendency for isolated glue spots standing out from the surrounding wood. Of course, if there are gobs of glue here and there due to localised bleedthrough it's important to put a bit of extra effort in to remove them. Slainte.
