Some burnishers I just made
Dominic in Buck's County PA
>Hi Gang,
A week or so back I posted a question regarding some scrap steel I had come across and was planning to use as scraper stock (Scrapers from Scrap steel? ). During the discussion it was suggested to me that I should use a harder burnisher, one that is also polished.
At this point enter Harry. A fellow woodworker who happened to have some hardened piston rods laying about. He kindly offered them to me because he didn't have the time to make burnishers out of them. I accepted his generous offer and promised to save one of them for him.
Several days ago these hardened steel piston rods arrived in the mail and I decided that I would make new handles for them right away. I needed a break from my ongoing projects. So I selected some Ash and Walnut from the scrap bin. I used 1/2" copper pipe for the ferrules. I was surprised how quickly the process went. I managed to rough the blanks, drill the holes, mount the ferrules and turn all the handles all in about 1 1/2 hours. That includes giving them several coats of BLO allowing them to dry.
I the chucked the steel rods into my lathe and sanded them all the way up to 2000 grit. You could see your reflection in them once I was done. After that I glued them into the handles and buffed the completed burnishers using a Beall Buffing System.
Photobucket
Like I said, one of these is going back to Harry, and I'm keeping one. The other two will be sent to two are bound to a couple deserving (fledgling) Woodworkers.
See ya around,
Dominic
Re: Some burnishers I just made
Very nice Dom. They must around
Scott Burr in Ben Lomond, CA
>a 1/4" in dia. because of the 2 groves!
Gee, I wanna be a deserving fledgling woodworker...
They must BE around. I'll learn to form a...
>complete sentence one of these days.
wilbur
>Really nice job, Dominic!
I know this is the wrong forum, but any tips on how to turn consistently shaped forms when doing spindle turning? If I tried to make 3 handles like that, they wouldn't look anything alike.
Dominic in Bucks County PA
Two grooves = 1/4" dia!
>You got me Scott! That's my secret. Now,...you must die!!!
LOL!
Kudos to you on remembering that groove businesss from my chisel handles! ("Check out the big brain on Scott!")
How do you get to Carnegie Hall?
>It's like the old joke, While visiting NY a man stops another guy on the street and asks him, How do I get to Carnegie Hall?". The second man replies, "Practice, Practice, Practice!" :>)
Seriously, after turning several dozen tool handles it's all muscle memory by now. It all started with my 3/4" Sorby Oval Skew. I liked the handle and patterned all my new handles off of it. I copied the profile onto paper and then made a negative image template out of hardboard. I used to hold it up against my work to make sure I was following the profile. Now, since I've done so many I don't even need to look at it.
Jack Guzman from Maine
make a template
>Wilbur,I'm a real amateur on the lathe but I just had to make 14 turned ballusters for a railing I'm repairing.The thing I did to get started was make a template with 1/4" ply that would fit my balluster if laid against it, then using that and a caliper to get thickness right it was a breeze.When I make chisel handles,I keep them simple and eyeball them.You can tell Dom is a turner by his handle design.---Jack
Send me one and I'll keep my big mouth shut.
>I'm too young to die!
I wish...
very nice...
Alan DuBoff
>Dom,
Very nice. Seems wise to use the piston rods, they are hardened. Most tool steel that is available for sale is not hardened and comes annealed. In that case it would require hardening.
Regards,
Alan
