Just bought a Stanley 45 it is neet
Wayne
>I picked it up on the bay it wasn't listed where it should have been so I got it for a good price. I have only played with the 1/16, 1/8 bead and the 3/16 plough and it seems to be a really neat tool. I was reading on "Blood and Gore" and it kind of scared me a little as to if I wanted to buy one or not. I guess I need to try some of the bigger irons before I make a final decision as to like or dislike. Any words of wisdom would be appreciated as to its use, and what to watch out for.
Wayne
Re: Just bought a Stanley 45 it is neet
Re: Just bought a Stanley 45 it is neet *LINK*
>Pick up one of the how-to manuals, online or purchased. Alf (Alice Frampton) has a good collection of online scans on her Cornish Workshop site, linked below.
My biggest lesson in learning to use mine was to be sure to measure from the fence to the body of the plane front and back, to make sure it's parallel - tightening the screws tends to knock it off parallel (and the screws affect the fence in opposing directions). If your fence has a fine adjustment, use it - set your fence slightly away from the final setting with the screws that clamp on the rods, adjust the fence to final with the fine adjuster, then hold it parallel to the body as you tighten the fine-setting clamping screw.
My second biggest lesson was one you'll find in the manuals: start your cuts at the far end of the board and work slowly back until you're getting a full cut. For reasons I don't fully understand yet, this makes for better alignment.
My third biggest lesson? Watch out - once you own and have learned to use a 45, you're on a slippery slope to wanting even more planes.
Alf on combination planes
Yea, Just one...
Scott Burr in Ben Lomond, CA
>Your going to have a buttload fun flattening and sharpening all those blades.
Good luck!
Frank D. in Montreal
>Hi,
Definitely check out what Alf has to say. As to what to watch out for, I'd say: the wood you use. Choose wood that works with the tool. Straight grained, and always use the plane on rising grain (easy to plan for once you get used to it). As Scott alluded to, shaprpening is an issue. Pick a system that seems practical and doable for you, and stick with it (there are many possible sharpening systems that work). Once you're up and running, and have sharpened/tuned the blades you use the most (maybe 5 or 6 blades), things go a lot faster (pick up the plane and go for it). (confession: I don't have a 45, but love my 55).
Wood is so neat hope the EPA doesn't get rid of it
Wayne
>I think things went backwards for me I first got an old molding plane and liked it so much that I got the 45. Now I am going to try and make a couple of molding planes hollow and round just to see if I can. I just love working with the wood planes they are so quiet and they do a fine job so smooth no chatter marks to sand out. And I can hear "Abba" and whistle while I work.
