hand saw
david schaefer fairbanks ak
>has any one knowledge of George Bishop rip saws. a fellow in this town has one and wants more info on the company thanks in advance
hand saw
Re: hand saw
Ray Gardiner
>It depends,
Henry Disston had a line of saws branded Bishop,
but could also be George Bishop (Lawrenceburg IN 1886 to 1919) (refer EAIA)
There was also a Sheffield Maker Bishop, Weldon & Carr (1797) also there was a sawmaker Peter Bishop, Sheffield late 18thC
A picture would be some help with clarification.
The image below is the Disston Bishop.
Regards
Ray
Bishop
David Miller from Iowa
>Probably a George Bishop - decent enough saw, although the blade tends to be more brittle than a Disston and teeth can break off when setting (DAMHIKT). Bishop saws generally had a griffin on the medallion, and the firm moved from Cincinatti to Lawrenceburg in 1899 so one can get a rough date around that as the City is often marked on the medallion.
Indeed..
Bob Demers
>Geo H Bishop was a maker in Cincinnati Ohio, perhaps better known for their line of adjustable saws. They had a stair saw with a slotted thru back spine which with a lever, would loosen the saw plate which could then slip up and down (or be completely removed). Pat jan 06. They also had a few more obscur patented adj handles ones.
They moved to Lawrenceburg Indiana shorthly after as seen in this advert from 1910.
I believed they are the Bishop that got shawllow, err bought by Disston. They did make regular handsaws also and competed with Disston.
Bob
Example Bishop hand saw
Bob Demers
>Here is pic of a Bishop handsaw
Applewood handle has 5 steel screws including medallion. Medallion is marked, G. H. Bishop & Co, Cincinnati, O. (with Griffon logo in center). Handle has a beautiful reddish varnish mostly intact, especially nice on frontside, and very nice wheat carving. In very good condition with very minor edgewear. Blade is 8 teeth per inch, with very minor pitting and darkening from rust residue. Has a couple of relatively minor kinks in it, has a been sharpened a few times, and very sharp. Etch is light but somewhat discernable. Saw measures 28 3/4" from blade tip and back of handle ear.
Yes, its from an old Ebay listing, circa 2005 :-)
Look like your friend's saw?
Bob, reaching back in dusty DVDs
Re: Bishop
Marv....... Northern California Lake Co.
>David,
Disston teeth break also. The overall quality of Disston saws was very inconsistant, including the hardness of their saw plates. I have filed saws that had hard spots along the tooth edge, while the rest of the saw edge would be not brittle at all. Some of the problem had to do with smithing or hammering the plate for straightening and tensioning. They didn't only have the masters doing the smithing, they also had apprentices doing it. I hold my breath everytime I set the teeth on an old saw, just waiting for that horrible "klink" sound that means retoothing the saw or a lot of heavy jointing and refiling.
Marv
About saw plates
Bob Demers
>That would makes sense, since Disston was really pumping them out in huge daily quantities.
Disston was a pionner in steel making and produces their own steel.
I often wonder when I hear about snapping off tooth on old saw plates if some of the brittleness was not induced at the cleaning/restoring stage?
Electrolysis comes to mind in this reguard.
Ive never done that to any of my old saws, mostly out of that fear, prefering instead to scrap and sand the old laborious and dirty way.
I also realise that in some case, using the wrong sawsetter, or trying to put in too much set, or wrong techniques would also contributes to broken teeth.
Just wondering:
Do old sawplates becomes brittle with ages, or that brittleness was imparted at the manufacture, or could be bring about by restoration techniques?
Bob, who has often wondered
Re: About saw plates
>Hi Bob,
I restore a lot of old saws. I don't use the electrolysis method. I only clean by scraping and sanding.
I use a minimum of set, just enough to prevent drag in the kerf. I do in fact run across a plate with a hard spot or the entire plate will be harder than another. I think that's a factory thing. The hardness is revealed while filing.
I really don't know if spring steel gets harder with age. Who knows, maybe it gets softer.
I suppose some people break teeth because of a lousy saw set. I will only use a Stanley 42X. The angle that a pliers type saw set will bend the tooth varies from saw set to saw set. A 42X bends the tooth at 15 degrees. I've measured saw sets that bend as much as 23 degrees, Somax is a good example with too much angle.
Even with only 15 degree bend, I still break a tooth from time to time. In most cases, it's been on a Disston saw. On the other hand, I recondition more Disston,s than other makes. My favorite saw to reconditon are the Simonds. I just finished a No.72 Blue Ribbon $2.00 saw. I have it scheduled to start on eBay tomorrow evening. I'll include one of the pictures.
Marv
Re: Bishop
Alan DuBoff
>Nobody should let the idea of a tooth breaking, to stop them from sharpening their saw. It is only a saw after all, these tools are not rocket science.
You don't need any college degree to sharpen a handsaw. :-)
Re: Beautiful saw!
Glenn Madsen near San Francisco
'Nother winner Marv...
Scott Burr in Ben Lomond, CA
>One of these days, you'll receive a package...
Re: 'Nother winner Marv...
>Scott,
You keep on use'n that dull saw of yours, and I'll have to file in all new teeth. Try to leave just a little of the teeth so I can judge where the gullets should be. How bout if we file every other tooth rip and every other, other tooth crosscut?
Marv
PS..thanks for the koodoes.
That's the problem!
>I can't use it. With the new job comes no time too. It all sucks but it's sooooo good too.
Just happy I have one one still...
