Re: how to taper a blind hole
ThomD
>I wouldn't necessarily assume there is no way for the non-tapered holes to work. The whole ladder back chair thing depends on non tapered blind holes.
If you want to make your own reamer, the one that John Alexander promotes is actually more effective in certain regards than the all metal high tech ones. I built one with nothing more than spoke shaves and a drawknife when I was away from my lathes. If you have a lathe it is a few minutes work. Like most reamers it is designed to pass through a through-hole, but I don't see any reason why it couldn't be engineered short. The only problem I had when making mine was that all the available blades had been converted to Japanese style blades, even at the Big Box stores, but they may work also, and finding the western type key-hole saw is not impossible. Check Alexander's woodworking site. This is the kind of tool you could have working by later tonight.
Another option would be to find an appropriate short tapered chucking reamer. There are lots of options particularly if you were able to bob off the end of a longer one. A keystone reamer looks like it might work, ebay often has "used" reamer, the provenance of which is open to question, I have always worried. My only concern with this approach is that you need enough depth in the seat to house your tapered part and room for it to move up in, and a solid top over it. That is a lot of stuff happening in the normal seat thickness, which is why so many ar designed for full penetratio, which may be a more workmanlike option. I would probably turn the underside with a raised ring to give extra meat, then remove the excess in a sculptural way.
You often prefer a high tech solution, Bill. One that works extremely well with tenons, goes like this.
- You drill your blind holes to a max diameter that will be the same size as a shoulder cut on your leg, using a forstner bit. You drill to near max dept, but you do the last 1/4" at a smaller tenon depth, by 1/8 to 1/4" in diameter, smaller diameter is better so long as the tenon doesn't get fragile. This can be thinner than one imagines because the shoulder is doing a lot of work in the final joint.
- You use a second Forstner bit for the smaller diameter to full depth, and it's point will center in the point hole of the other drill. You turn your tenon so that the shoulder is a precise fit for the larger diameter, and you give that a little bearing, then your reduce the rest of the tenon to the minor diameter.
- What you end up with is parts that perfectly index on the shoulder and tenon parts, can have a tight fit without splitting, but leave a precise cylinder or space around the tenon for most of it's penetration. Or you could look at it as a tapered design, except you only controlled for the end and the shoulder of the tenon.
- You mask the exposed surfaces and glue up with boatbuilding epoxy, flooding the hole. Done right it is super strong, very clean looking, and as impervious to racking or moisture issues as any joint imaginable.
