Disson Saw No. 240 Metal Cutting
-e-
>I'm helping with the tools for an upcoming estate sale in Benicia, ca.
I'm looking for advise on the Disson Saw No. 240 Metal Cutting -- some surface rusting but handle and blade are straight and in good condition. How does one rate condition?
Any suggestions on a price for this saw?
Re: Disson Saw No. 240 Metal Cutting
David Miller from Iowa
>Not too much, $5 at best. It is not old enough to be sought after by a collector.
Kinda rare, but little demand...
Alan DuBoff
>I think it's kinda cool.
Those metal cutting saws are not very common, more collectible value, IMO. Nobody really would use them anymore, they usually have pretty fine teeth. With modern hacksaws I see little use for them, but they are not as common as wood cutting handsaws so they will eventually have some collectible value.
The one pic'd is newer, AFAICT, like from the 50s or 60s, or broken and reshaped into what it is.
Marv....... Northern California Lake Co.
>Hi Mr. e
That particular saw is often referred to as a "nail-saw". It's main purpose was to cut nails off between two boards. The boards would be pried apart enough for the blade to slip in and saw off the nails. Usually one would just pull the nails out, but sometimes when tearing down a wall or some other structure while remodeling for example, pulling a nail or nails out isn't possible.
The teeth are usually about 12PPI and are filed rip with zero set. I have one that was made by Richardson Bros. I added a little set to the teeth and use for sawing wood. All the major saw makers made them. I see them on eBay from time to time. They don't sell for much. When they are sharp, they work pretty good on aluminum and brass, even better than a hacksaw. I had to make some angle cuts on some aluminum awning panels not long ago. It worked quite well for sawing something wide and flimsey like that.
Marv
-e-
>thanks, david
Re: Kinda rare, but little demand...
-e-
>so probably price at 20 and barter down
-e-
>thanks marv!
great information to know! i can now provide a story with the saw!
Jack Guzman from Maine
>I have one of those.I had to replace some windows in a shack with no power within reach.I had to cut through wood and nails both to resize the opening.That saw worked slick for that job.You ought to keep it E. It may come in handy some day.---Jack
