Have a question? Ask Woody!
A bit of She-oak, add some brass and ...
>I decided to make another brace. This is small, to be used as would an eggbeater, such as for drilling holes for screws. It can also be used as a driver.
The total length is 400mm (15 3/4") with a 100mm (4") throw.
Materials: West Australian She-oak body and Tasmanian Blackwood pad.
The pad ...
An old, rusty Stanley brace sacrificed itself for the upper connection. This turns so sweetly.
Finally, the chuck is made from a spring-loaded clip-on driver holder. I wire brushed the anodising back to a steel finish.
Construction: after bandsawing out the basic shape, the final body shape was achieved with rasps and scrapers. Sandpaper to smooth. Oil and shellac finish.
Thanks for looking.
Re: A bit of She-oak, add some brass and ...
Bob Demers
>Very nice work as usual Derek.
Any problems releasing the bits :-)
Bob, the jokester
Marv....... Northern California Lake Co.
>Derek,
Very nice work, and creative too.
Do you just allow the hand grip to slip in your hand as you use it, or do you perhaps use a soft cloth?
Marv
That IS cool !
steve mackay
>Hi Marv
The finish is really smooth. I sanded to 800, burnished the danish oil by buffing, and then did the same for a mix of shellac and hard wax. So there is minimal friction. Just let the handle area slip in the web/fingers. This is only for screws, so not a lot of effort is necessary.The pad mechanism is lubricated with a touch of lithium grease, and it spins and spins.
Ellis can this be saved somewhere?
Tom Colligan
>Really nice, Derek; but I think you've done this before 'cause I check your site regularly to see your articles, etc. Tom.
Did you add a bearing?
Alan DuBoff
>Derek,
Did you add a bearing to the top knob? Looks like you may have.
Honestly, this was one of my favorite designs in the toolmaking contest last year, and I'll tell you what is striking about it to me.
The shape of the tool is round, which we often associate with the lathe in woodworking, but the shape of the tool overall would not allow it to be turned on the lathe. I love how you leverage a round object in such an unusual fashion, and it shows a tremendous amount of handcrafting to do so.
It is without a doubt, one of the best executed designs because of such, IMO.
Not only is this a beautiful tool, the warmth of the wood pours out from it, just making it inviting, I wish I could grab it over the web!:-)
Nice work as always, thanks for sharing.
ajd
It'll always be right here
Ellis Walentine, Host
>...if you click Search Current Messages. After the next 10,000 messages have been posted, it will revert automatically to our Hand Tools Archives where it will live on until closing day. Bookmark it if you want to refer to it again.
Cheers,
Re: Ellis can this be saved somewhere?
>Hi Tom
Thanks ... and yes, I made one in Jarrah for the WC tool comp last year (that one is in the competition archives). I was asked recently to enter a tool in the competition being run by the Australian Wood Review magazine (this is the premier Aussie woodworking mag). Since I had gifted the brace I made earlier (to a gracious individual who promised to revere it as it deserved :) ), I was looking for an excuse to make another, this time for myself.
I was also determined to make good for an impulsive decision I made with the competition brace. I had built the connection for the pad out of tubing. It spun well, but very (very!) slightly off centre. I really should have just left it as part of the charm of a handmade tool, but I experienced an obsessional moment .. and added a dab of epoxy to fix it in place. I was marked down for it not spinning. I am sure that the pad could be released with a spot of heat (from a heat gun). Anyway I wanted to make amends. And this time I have a great result, one with which I am very pleased.
Here is the connection on the new brace. You can also see the rough sawn She-oak shape prior to rasping it.
Re: Did you add a bearing?
>Hi Alan
Thank you so much for those kind words. And, yes, the pad (is there a better name for this?) now has a bearing. I added a touch of lithium grease to it and it spins smoothly.
I think that this shape is very tactile. It just begs to be held and stroked .. you have to take careful otherwise you will end up in a trance ... :)
Shaping it ... well it starts out easily enough while you have your reference marks ..
... but these soon disappear and you are left with just the ends to guide you. It is all by eye after that. I did make a scraper that helped size the body.
Time now to build a tool box for it.
That's the cat's meow with the bearing!
Alan DuBoff
>Derek,
That is very nice with the bearing you added, I bet it works great.
Great pics, maybe they will inspire me to give a shot at making something similar. I do like the round stock.
Could you explain the chuck a bit more?
Scott Burr in Ben Lomond, CA
>As usual, very nice Derek. I'm a bit confused about the chuck, what did it come off of?
Hardware images
>Hi Scott
As I mentioned earlier, the chuck is, in fact, a spring-loaded clip in adapter for a drill, used for quick changes of bits. It was the realization last year that this could be used for a "modern" brace that motivated me to build one.
The brass knurling comes from a hose connector. One of my aims is to show that tools can be made without special metal working equipment.
And a close up ..
To recap, the bits are held in mechnically, not with magnets, so the connection is excellent - that is, there is no danger of a bit falling out.
Here is a picture of the wooden parts ...
charlie belden
>Well done sir. Make that very well done sir. Modern hardware on a classic tool. And it's pleasing to the eye as well.
Thank you Derek!
>Your pic's are worth a few words too...8^)
Again,
Thanks
