Follow up on stuck eggbeater chuck
>I finally got into the workshop where I could test out the advice recently received here.
Essentially, the suggestions ran to oiling the chuck thread and trying some Loctite.
Incidentally, I tighten up the chuck as others do. Here is my grip ..
I oiled the thread. In one this was worked. In the other ... Well, there I was drilling away ...
And when it was time to remove the drill bit, it was still stuck fast.
Then I had this flash of insight. The jaws has not released - this is what was causing the problem.
So I tapped the end of the bit against the bench ...
And the chuck released and the bit fell out ...
I hope this helps someone else.
Re: Follow up on stuck eggbeater chuck
Bob Demers
>So i'm guessing, if the jaws wont release, it must be because of friction between the outer surface of the jaws and the inner surface of the collar.
Normally this area is covered in grease, often that old grease dried up and cause binding.
Suggest taking the chuck apart, clean it and put in new grease.
Bob
Warren in Lancaster, PA
>Derek, you might try this grip. When drilling, work the small knob with the right hand. Then pull the knob toward the handle and leave the right index finger curled on the knob as you grip the big handle with the rest of the right hand. Loosen the jaws with the left hand. If I drill three holes with three different bits, my right index finger never loses contact with the knob, controlling it all the while.
You might also try closing the jaws without any bit (so the outside of the jaws are somewhat exposed) and putting a little grease on the outer surface of the jaws. I think that surface is where you are getting the sticking now.
Marv....... Northern California Lake Co.
>Derek,
You might try smoothing the very top edge of the opening of the chuck where the jaws extend out through the opening. Over time with a lot of use that edge can get a bit sticky. Another thing I do is to polish the side of each jaw that slides up and down the inner surface of the chuck housing. Also as mentioned, the inside surface of the housing should be clean and smooth.
Grease works ok, but it's best to use a very light oil. Not a lot of it, just wipe it on. Grease along with crap getting down inside becomes gummy and no longer lubricates as well.
The Millers Falls No.5 that you show in the pictures was one of the most popular eggbeater drills that Millers Falls made. The wider than usual crank gear is wider for the purpose of grasping it with your fingers when using very small drills when drilling very delicate things. It's the only drill that Millers Falls made with the wider gear that I'm aware of.
Stanley made an H1220 Handyman with a wider gear. I also have a couple German made eggbeaters with the wider gear. I much prefer the Millers Falls though.
The other most popular Millers Falls eggbeater was the No.2 that you have.
Marv
