Scrapers from Scrap steel?
Dominic in Bucks County PA
>Hi gang,
I posted this on another site and wanted to get some feedback from teh resident machints and tool makers who frequent QC.
I recently accepted an Engineering position at a mfg company that uses rolls and rolls of steel to make their product. They use 1095 Blue polished steel (Rockwell C48-52 hardness), 1095 Brite (polished) with the same specs as prev. mentioned, and 301 Hi Yields SS (Rockwell C48-52 hardness). All the steel mentioned come in thicknesses from 0.010" all the way up to 0.0625".
I took a look through the scrap bin and was amazed at the amount of usable (to me) steel that was heading out to the recycler. With their permission, I took a couple pieces home. One was a 0.025" thick piece of 1095 Blue polished. The other a piece of 0.010" thk 301SS Hi Yield. Little fact-oid here: The 301 SS Hi Yield the only SS I've come across that is magnetic! The cold forming process used to obtain the thickness we want aligns the molecules and enables this. Cool eh?
Anyway, I cut the pieces to size and polished them up. After that I sharpened as I would with any scraper. The 1095 Blue Polished stuff was a PITA to raise a burr on. But eventually I got it to work. But it was like trying to raise a burr on my No12's Hock Scraper Blade. The 0.010" thk 301 Hi Yield was a joy to use and was giving me BEAUTIFUL shavings in short order. Plus I liked that fact that it was SS and wouldn't rust.
The burnisher I used should have been sufficient. It's a Hock Burnisher. From the TFWW web site it reports, "This 3/8 of an inch by 6 inch burnisher is hardened to RC 64 and polished to a mirror finish". So this is not just a screwdriver that I'm using to burnish!
I should mention that all the scrap pieces have a No1 rounded edge on them. This means that the edges have been ground to a radius. I had to file that away before I was able to use them as a scraper. Rather than file all that, I LIGHTLY touched the edges up at my disc sander. After that they were filed flat.
I looked at LV's website and noticed that the Bahco (formerly Sandvik) scrapers are listed as Rc48-52. Now, I was wondering WHY I was having such a hard time with filing, and stoning the edge on that hunk of 0.025" thk 1095 Blue Polished Steel. The hardness is right in line with the published hardness of the Bahco Scrapers. Could it have been the bluing? One thing, the term "Blue Polished [b]is[/b] referring to a corrision resistant finish (bluing) that has been applied. I know this since I can somewhat easily scratch it off.
See ya around,
Dominic
