Finish for plywood work table (NOT mine!)?
Dominic in Bucks County PA
>Hi gang,
Since everyone here at work knows that I'm a wood worker, I've been asked for some assistance.
There is a HUGE plywood layout table that is used in the plant. This table is 16'-8" long x 4'-4" wide. The workers lay out fabric (of varying types and thickness) and then staple the material down so they can mark the fabic for gluing.
Personally, I HATE the fact that they use staples. And on plywood it's even worse. But until I come up with something better I need to work with what they have in place.
I was wondering what kind of finsih to recommend. They need something durable, easily renewed, and that can take the abuse of stapling.
I think shellac would be perfect. However, I not sure polyurethane would be bad either.
Any help?
See ya around,
Dominic
Re: Finish for plywood work table (NOT mine!)?
>It would seem like shellac would be more easily renewed. How much finish does it need? Would a long oil varnish like Watco do the job? This is equally easily renewed.
Shellac would have the advantage of quick drying, thus minimizing lost production time, if the table is in frequent use.
ThomD
>Plywood is a polyurethane thing. Assuming normal fir ply, it will soak up a lot of shellac. Is this is one of those deals where people fold material back and forth and then cut them out with one of those electic knifes. Normally people use pigs of some heavy metal like drafting duck, or old irons from the days when they were just slugs of metal. Today some kind of exercise weight with a handle on it from Walmart would seem similar. They need storage where they will be used, like a hook or shelf under the table, or some table surface you don't need so that they don't have to be carried around a lot
>Thom,
You wrote:
"Plywood is a polyurethane thing. Assuming normal fir ply, it will soak up a lot of shellac. Is this is one of those deals where people fold material back and forth and then cut them out with one of those electic knifes. Normally people use pigs of some heavy metal like drafting duck, or old irons from the days when they were just slugs of metal. Today some kind of exercise weight with a handle on it from Walmart would seem similar. They need storage where they will be used, like a hook or shelf under the table, or some table surface you don't need so that they don't have to be carried around a lot "
Thanks for your input. Spar varish might be do-able.
BTW, weights are a good idea. But they would not work for all the sizes of material we use in this application. Some of the pieces are too small. I suggested rare earth magnets but was shot down because the size needed wouldn't be strong enough, and going with bigger RE magnets would make them too difficult to disengage. (Read that as people being VERY resistant to change).
KenI
>Gee Dom, how big a magnet are you talking? If you turned a few handles (pen/chess piece/chisel handle sized) and put the magnet on the bottom, I'm having a hard time believing anyone would have trouble moving them around.
Ken
>Ken,
I brought in some 3/8" diameter x 1/4" tall magnet and the women in the sweing department complained that they were too hard to disengage! I told them that I could turn a handle but that got about as warm a welcome as flatulence in a church. To say most of these people are "set in their ways" is putting it mildly!
Resistance to change vs. optimization of process *LINK*
>Sometimes it's resistance to a new idea; sometimes the process has already been optimized. Hard to tell, without experiments.
Those on/off magnets Lee Valley and others sell might be the answer, but could be too pricey - although they could pay for themselves in saved staples and reduced damage to the fabric.
These magnets
Wiley Horne--So. Calif.
>Hi Dom,
What problem are you solving with the finish? Does the surface need to be cleanable? Or smooth so it doesn't catch at the fabric?
Wiley...thinking maybe Dom better let the women decide from samples on which finish _they_ want
I'm on the same page here. Kinda sorta...
Scott Burr in Ben Lomond, CA
>Why finish the table tops? I think it might be better to cover the tables with something replaceable. Masonite is one option. Personally, and you should know Dom.
I know we're about the same age and do roughly the same type of job. Witch means you probable spent some tine behind a drafting table. that table would be covered in a green, several layered plastic (PVC, vinyl, etc.) sheet that was self-healing and sealing to staples, pins, x-acto knifes, and alike. Just something to think about...
