REAL MILK PAINT
Honing compound. Veritas Green or Veritas Gold
Victor Parisian
>I have a stick of each (don't ask how that happened, I don't know). So which is which or are they both the same just diff colors?
I spent a few minutes in the shop today and sharpened the Hock blade from my Stanley jointer with the best results to date. This after reading the recent discussion on sharpening.
Victor - suffering from a late winter cold in Houston cough cough cough.
Re: Honing compound. Veritas Green or Veritas Gold
Veritas Gold ??
Bob Demers
>AFAIK, Veritas only makes and sell the green stuff.
There are a variety of buffing compound somewhat colours coded, Red, white, tripoli brown, green, gold are some of the ones I know about.
The differences among them related to their intended usage (various metal or plastic buffing) and their grits.
I do have a bar of gold coloured honing paste from Flexcut that came with my shaped strop, sold for carving tools.
I also have all of the above coloured honing compound bars, but find my trusty old 10 years old bar of LV green my best favorite for that final honing edge.
As anything else related to sharpening, use what you are comfortable with. If it work well for you, stick with it.
By the way that bar that LV sell, will last you a lifetime of sharpening in my experiences.
Bob
Veritas Green *LINK*
Bob Demers
>Quote: It is primarily chromium oxide admixed with other fine abrasives (0.5 micron particle size) to give the best combination of cutting speed and fine finish.
Veritas Green
Flexcut Gold *LINK*
Bob Demers
>Quote: Its blend of aluminum and titanium oxide provide a balance between aggressive removal of hardened tool steel and offering a high-color polish
Flexcut gold
Re: Flexcut Gold & staining
Jim in VA
>I've heard good things about Flexcut gold as as honing compound--especially from carvers, but cannot comment on its honing ability from personal experience. I bought some and it got on a paper pattern and stained it badly with what looked like an oil stain. Seems to transfer to hands too. Haven't had the problem with the Veritas green. So the Flexcut went in the trash. Others might have different experiences.
Frank D. in Monteal
>I've used both and much prefer the Flexcut. It was designed for hand use (hand honing) and IME gives much faster results than the green paste. Since I discovered the Flexcut paste I use oilstones a lot more often.
Flexcut Gold & staining. Umm Frank..
Scott Burr in Ben Lomond, CA
>You said "Since I discovered the Flexcut paste I use oilstones a lot more often."
Let's hope not...
Re: Veritas Gold ??
Victor P
>Thanks for your response/explanation.
So now I have to go paw around on the shelf to find that old label.
I've got to get to the bottom of this. I bought them at the same store (i think) and the packageing was similar (identical?). I keep both of them together in the blister pack "tubs" that I bought them in.
Rob are you reading this? Did you ever sell a gold or yellow (light tan?) honing compound stick in a blister pack?
Victor - still amazed that I can make the hairs "pop" off my arm with a Hock blade.
Actually Scott
Frank D. in Montreal
>Hey Scott,
Actually I do...I can go from the translucent to the paste on leather and get an edge at least as keen as with my 8000 Norton waterstone. I couldn't get that with the green paste (in a reasonable amount of time) so just didn't use my oilstones much.
Hope that's clearer
Flexcut it is... It's cast into the face of block
Victor Parisian
>Duh.
I really haven't used it that much.
Victor - going back to re-read the plusses and minus' of each.
Thanks Frank, I get it...
>I shouldn't have put my last sentence the way I did.
I think I do the same thing. Once sharpened the chisel (let's say) spends more time being stropped between sharpening... i.e. less time on the oil stones, or water for that matter. Also less on the coarser stones, lessin' you screwed the pooch...
