Which weighs more?
>A pound of wrought iron or a pound of cast steel?
Just kidding, what weighs more a cubic foot of wrought iron or a cubic foot of cast steel?
Stephen
Which weighs more?
Stephen
Re: Which weighs more?
wilbur
>Density of cast steel: 7.85 g/cm3.
http://www.matbase.com/material/ferrous-metals/cast-steel/gs-38.3/properties
Density of wrought iron: 7.75 g/cm3.
http://hypertextbook.com/facts/2004/KarenSutherland.shtml
So cast steel is a little more dense than wrought iron.
KenI
>Hmm. My brief search for density of wrought iron (7.75 g/cm3) seems to say that it is less dense than cast steel (7.8 g/cm3). Although, the site I found seems to have a long list of cast steels. A couple of them were about the same as the wrought iron number I found. The exact properties are going to depend on the exact composition of the material. Wrought iron and cast steel seem to be too broad of terms. I'm sure someone with a metallurgical background will have something better to say.
Exactly!
Scott Burr in Ben Lomond, CA
>Not enough info to truly make up a answer...;^)
Really, what type of each material? Oh yea, stop making do math on teh weekends!
Andrew F in Australia
>Iron has a density of 7.85 t per cubic metre, slag (molten limestone,) has a density of 1.2 tonnes per cubic metre.
As the wrought iron contains a portion of slag, it's going to be lighter. The numbers you specify seem reasonable.
Cheers,
Andrew
Todd Hughes
>Steel is heavier then wrought iron, the lower the grade of iron the less it weighs too.
I used to always be on the look out for wrought iron scrap and got to so I could many times get a good feel if it was wrought iron just by lifting it...felt lighter then it should.
Why do you ask which one is heavier?...just wondering....Todd
Thank You
>Thank you all for responding, I got the information I was looking for. I am continuing to examine the use of wrought iron and cast steel in nineteenth century tools.
When analyzing the amount of steel used to laminate blades, the weight of each material must be considered. Although the difference in density doesn't seem to be a lot, statisticians like numbers.
Thanks again.
Stephen
Dad says . . .
steve mackay
>Sorry but, ask Dad The Tool & Die Maker a question and you get the WHOLE smash !
MATERIAL DENSITY MATERIAL DENSITY
Aluminum 1100 0.098 Magnesium, Cast, AZ91A 0.066
Aluminum 3003 0.099 Manganese 0.267
Aluminum 5052 0.097 Molybdenum 0.369
Aluminum 6061 0.098 Nickel, Pure 0.309
Aluminum 7075 0.101 Phosphor Bronze 0.32
Aluminum, Cast, 356 0.097 Platinum, (99.9) 0.775
Aluminum, Cast, 384 0.102 Silver, Fine 0.379
Beryllium 0.0675 Stainless Steel 301 0.285
Beryllium Copper 0.298 Stainless Steel 302 0.284
Brass, Cartridge 0.308 Stainless Steel 316 0.284
Brass, Free Cutting 0.307 Stainless Steel 420 0.278
Brass, Naval 0.304 Stainless Steel 430 0.283
Brass, Red 0.316 Stainless Steel 440 0.279
Cast Iron, Grey, CL35 0.252 Steel, Mild 0.284
Chromium 0.26 Steel, Carbon Alloy 0.284
Copper OFHC 0.323 Tin 0.264
Gold, (99.95) 0.682 Titanium 0.163
Iron, Pure 0.284 Tungsten 0.697
Kovar 0.302 Zinc 0.258
Lead 0.41 Zinc, Cast 0.24
Magnesium 0.063 Zirconium 0.23
Smart Arse!
>Let dad do you homework...8^)
ROFL ! . . .
steve mackay
>Now that hes got e-mail I send my math up to him also ! I'm very math challenged and the Man does trig in his head !
