Question about eggbeaters
>I have a three eggbeater drills and they all drive me nuts when it comes to removing the drill bits. Maybe I just have never learned to do so. Maybe mine all have the same fault (they are old). Maybe I am just dense. Maybe all of the above.
Obligatory picture :)
The issue: when I untighten the chuck, instead of this loosening the jaw to release the bit, the chuck itself comes off. Usually I have to hold the drill bit in a grip. I have tried tightening it up less securely when inserting a drill bit, but this makes no difference - the bit is still clamped tightly and the chuck unwinds.
What do you do?
Re: Question about eggbeaters
#2Re: Question about eggbeaters
Marv....... Northern California Lake Co.
>Derek,
You have to really tighten the two parts of the chuck housing so they won't unscrew. On my Millers Falls No.2,s, the top part of the chuck housing has two holes in it. A spanner with nibs is used to tighten using those two holes.
My No.5 has slots for that purpose.
Your Yankee should have flats you can use a regular wrench on. When you tighten, put the larger part of the chuck housing in a vise with soft jaws so you don't muck up the knurl. Don't tighten too much on that larger housing when in your vise or you might compress it out of round.
Marv
#3Re: Question about eggbeaters
>I don't know if they sell it in Australia, but surely they sell something equivalent: there is a product called "Loctite" (to my surprise when I looked the company up, it's German-owned and claims international sales) that, slathered on the threads of things, binds them up. There are various strengths, up to one that locks bearings in place. The one that I'd consider for your purpose is put on after the fastener is installed, and seeps into the threads by capillary action. It's the weakest of the products, which is why I think it's the best - you can disassemble the chuck later if you need to. In the U.S., hardware stores and auto parts stores carry it.
I'd remove the chuck from the drill spindle - you don't want to lock the chuck on the spindle, which is surprisingly possible (as witnessed by the little wood lathe on which, in locking a drive center on a 1/2" spindle, I managed to lock the spindle in the brass bushings of the headstock, even though the bushings were oiled). Get the chuck parts as tight as you can without messing up the knurling. Drip a bit of the loctite into the joint where the parts join, and give it 24 hours. Set the chuck with the jaws UP while you're waiting, to minimize the possibility of the stuff getting on the jaws.
Try it on your least favorite drill first - I've never done this.
If this makes you nervous, and you've got access to nail polish, slather a bit of that on the male threads of the chuck parts (color irrelevant...) before assembling the chuck. This is an old motorcycle field repair trick.
#4Re: Question about eggbeaters
Warren in Lancaster, PA
>Derek, you might want to clean and oil the threads on the shaft that goes into the chuck. My chuck is not at all tight where yours comes apart, but it is looser yet on the shaft, so when you turn it that is where the movement occurs.
#5Another thought:
>Hi Derek,
Another thought regarding your chuck.....I first make sure the chuck will screw onto the main shaft very easily. I use a small steel brush to clean the threads, both on the main shaft and the female threads in the chuck part, followed with a little light oil. I'm most happy when I can give the threaded part a spin and it turns a little ways on it's own. Then when you tighten that threaded part into the larger housing using the slots or holes or flats, it will not loosen when you release the grip on a drill.
One more little thing to be mindful of....make sure there aren't any burrs or other junk on the two surfaces between the threaded part of the chuck and the housing where they need to properly seat when screwed together.
The Loctite that Bill speaks of is good stuff, but it does have it's place and can be tricky to use. Try not to go there. It worked great on my glasses to lock the tiny little screws from loosening every few days allowing the lense to fall out in my food. If you ever want to use Loctite on anything and need to get it apart, just heat it up a little. The stuff works quite well, but it doesn't like heat.
Marv
#6Re: Another thought:
>"The Loctite that Bill speaks of is good stuff, but it does have it's place and can be tricky to use."
Agreed. I recommended the weakest Loctite for this application for that very reason - not good to heat up a tool part in general.
I used some of this grade Loctite on one of the screws that holds the cap on my Stanley 78 - though why I did is now lost in the mists of my memory. The screw was from the hardware store, and I'd never been happy with it, as the head was too large and made removing the iron difficult. Yesterday, I removed it and replaced it with the screw from a No. 191 that I bought for parts (someone had done a really bad brazing job on it at the mouth, leaving it out of square in all directions). I didn't need heat, just a little extra grunt on the screwdriver.
If Derek can get the parts tight without this, though, that would be the best.
#7Re: Another thought:
>Bill,
I have a big O soldering iron that I use if I need to heat a screw, for example. I don't heat the whole tool, just the screw head. I totally agree about not being careless with heat around most any tool, especially one like a hand drill with various materials. A chuck such as we are discussing here could be safely heated because it could be done with the chuck removed. It doesn't require much heat to soften Loctite.
Marv
#8Re: Question about eggbeaters
ThomD
>Those are nice ones, I have a Schrode EB sold by LV, and it worked great other than having a whimpy drive arm though it doesn't really seem a problem. You could try winding some thread in the threads. Sounds like the catagory of fit was missed.
My only OT trick for tightening and loosening these things, is to hold the drill and handle in the left hand for tightening, and the right hand for loosening. That way the lever arm locks up better for firmer tightening. My thumb goes around the handle, and my fingers over the drive handle.
#9Tightening the chuck
>someone here taught me to get the chuck generally tight, then orient the crank handle so I can pull toward me, hold the chuck tight, and do the final tightening by pulling on the crank handle; reverse for loosening.
So far (other than using the North Bros. drills, which have a spindle lock, exclusively), this has been the best approach.
#10Re: Tightening the chuck
>I think Derek's original question was not how to hold the crank when tightening the chuck jaws onto a drill. His problem had to do with the chuck housing unscrewing instead of releasing the drill. I think that was his question....
Marv
#11Yes, but we're wandering off the original topic
>as this forum so often does...
#12Re: Yes, but we're wandering off the original topi
ThomD
>I thought that loose chuck stuff was covered off already?
I always figure the guy who said a picture is worth 10 000 words was reading my posts...
So here is a picture of the tightening position, and loosening is accomplished with the right hand holding. Finally a technology a left hander has an advantage with.
#13Re: Yes, but we're wandering off the original topi
>Any good mechanic would know that all you have to do is jamb a screwdriver into the gears. :-))
Marv
#14Well, yes and no
>Having spent extra time and money replacing parts on which the teeth got fouled up using the screwdriver technique, I would use jamming the gears only as a last resort.
You surely have more skill than I in this area, of course, and I'd never claim to be a good mechanic.
#15Re: Loctite
Tom MacGregor
>Loctite makes a variety of products including various strengths of threadlocker. The lightest bond is purple, medium is blue, strong is red. I use mostly blue and can take stuff back apart without heat. Just Google their site for tons of info. I used it to keep the rivet machines from shaking themselves apart at the Tubbs Snowshoe Co. for over 8 years - until K2 Sports bought 'em out & outsourced it all to China. Red & Blue are available in a Chapstick type container that doesn't drip all over the place.
#16Re: Well, yes and no
>Bill,
I was just kidding about the screwdriver techique...LOL
I would never do that.
When the drill was new, it didn't take much to tighten the chuck jaws onto a drill. What happens over time with lots of use, the inner surface of the jaws that clamp onto the drill will wear to the extent that the clamping is uneven along the length of the jaws. The drill should be inserted all the way in so the full length of the jaws are always clamping. But, as we know, we often times need that little extra length, so we tend to only insert the very end of the drill.
At least, that's my theory. Theories are usually wrong.
Marv
#17Re: Loctite
>Thanks Tom,
That chapstick idea is a good one. That's something new since I last bought Loctite. I've been on the same bottles for 20 years. Believe it or not, it still works. Loctite includes a lot of good products.
I'm trying to remember who made the first "Super-glue". Was it Eastman? If my memory is correct, it first showed up during the late 50,s, early 60,s? I remember becoming so dependent on it, it was disasterous if we ran out. Always had to have a little bottle of it in the refrigerator. I was working in the electronics industry at the time.
Marv
