Fluted drill points
Fluted drill points
Fluted drill points
Patrick Gibbons, Katy, TX
>Many eggbeater drills came equipped with fluted drill points. Does anyone know if these are superior to twist drill bits for use in an eggbeater? My Millers Falls #2 has this type of bit in the handle. They work just fine but I was wondering why these were supplied. On the Millers Falls history internet site one drill was listed as having a handle storage that allowed the longer twist bits to be stored. This implies that the fluted bits were used because of their size. But I would assume the smaller twist bits existed then as they do now. Is there something about the geometry of the fluted bits that works better at the speeds and for the hole sizes that an eggbeater operates with?
Re: Fluted drill points
Marv....... Northern California Lake Co.
>Patrick,
The flutted bits won't corkscrew themselves into the wood like a twist drill does, making it easier to drill with a crank drill. Smaller drills such as say, 3/32 and smaller, it really doesn't matter when drilling wood. However the eggbeater and breast drills were also used for drilling metal. With metal you would want a twist drill.
Marv
My thinking...
Scott Burr in Ben Lomond, CA
>Fluted drill bits were easier my manufacture than small twist bits. Also they more meat to them (cross sectionally) so they don't break as easy. I prefer them over twist bits for that reason. Also it's easier to back them out of a hole.
