Electrolysis Improvement
Tom MacGregor
>Since electrolysis used to derust tools tends to be "line of sight" I wondered if it was possible to improve the line. I picked up a salvageable V&B 907C on ebay and wanted to dunk the whole body at once, not my usual flip-it-in-the-bucket routine. I bought a cheap (under $5) plastic trough for soaking wallpaper long enough to immerse an object up to 30 inches long. A short chunk of sacrificial iron concentrated the rust removal on less than 1/4 of the plane body. I took a 5-1/2 foot long piece of 1/4 inch iron rod and bent it into a long U around the trough and hooked it up as shown below. I got bubbles the full length of both sides of the plane! I will note, however, that it's very easy to make a BIG mess if you're not careful dumping the liquid out of the trough. Please DAMHIKT.
Re: Electrolysis Improvement
>Cool - good idea.
You can buy those big troughs used for mixing concrete or compost and suchlike in home centers - about $5-10. If you put your wallpaper trough in one of those and dumped it into your storage container while in the larger container, it might contain the mess.
Nifty Idea! Thanks!
Scott Burr in Ben Lomond, CA
Marv....... Northern California Lake Co.
>Bill,
Do you use a battery charger for your power source?
Thanks,
Marv
I have yet to try Electrolysis
>I was responding merely to the problem of not slopping stuff all over the place - something (the slopping) with which I have oodles of experience.
