Japanese Hammer
Japanese Hammer
Japanese Hammer
Fred Peake
>I recently purchased a Japanese saw setting hammer (Ryoguchi-Asaritsuchi). It has a type of lamination that I have never seen before. Instead of the typical two part lamination of wrought iron and steel, this has a three part lamination of wrought iron, brass and steel. The brass is laminated into the wrought iron with vertical finger joints, and then the steel is inserted horizontally into the iron and brass. I've attached a sketch to show the sequence.
Does anyone have an idea of how this was done? Is this forge welded or was it just peined together?
Re: Japanese Hammer
Re: Japanese Hammer
Fred Peake
>Additional pic of hammer.
Re: Japanese Hammer
Re: Japanese Hammer
Fred Peake
>Additional close up.
Re: Japanese Hammer
Re: Japanese Hammer
wilbur
>I have no idea how this was done, but where did you purchase this hammer? I'd love to have one myself.
Re: Japanese Hammer
Re: Japanese Hammer
ThomD
>There would be two sets of mills one for the slot and the other for all the seration (or some mill filing). The steel insert would be placed into it's slot and the rest would be brazed with flux and brass. This would either be done in some kind of contained way, or more likely just blobbed up and then dressed to final dimension with a fire or abrassives, like a belt sander. The brazing takes place at a very high heat, high enough to harden steel. So that little chip could be hardened if the whole deal could be quenched. Or the chip could be a prehardened HSS which would hold it's temper at brazing temps, or it would be carbide, or it would be an air hardening steel, etc...
If you look at the carbide teeth on some circular saw, etc,,, you will see the same kind of brazing used. In some circustances it is all probably done with induction heat.
Here is an example of brazing bike tubing, if you want to see some artful work. This was in a thread on how the maker managed to get the donuts around the seat stay so neat and separated:
http://bp1.blogger.com/_eeYhBGkKfS0/SAaI1v1_QeI/AAAAAAAACA8/15MFmpQfQWU/s1600-h/metalwork+2008+209.jpg
Re: Japanese Hammer
Re: Japanese Hammer
Todd Hughes
>I guess maybe this could be considered some type of Mokume which is where several different metals are joined together, usualy it would be things like gold,silver, copper etc. and wouold be soldered together. You see this treatment with sword fittings.
In the hammer as somebody else said it just looks like an example of brass brazing the steel face onto the iron body. The finger joints are there to provide a better grip but in reality is only probably a decorative feature.
... If a hand made japanese hammer no doubt was forge brazed which is very easy to do [much easier then forge welding]. In forge brazing a piece of copper or brass is used to join the two items. I normaly would just wrapped the joint with brass or copper wire, heat up to some color shows and then flux with borax and then put back into the fire till the brass mets and runs into the joint. Take out and let cool. Is pretty fool proof. I used to make small iron snakes where thier skin pattern was done in brass using this method. Sort of a gimick but looked like it took alot of work and impressed people because they didn't know how it was done ,[or how easy it was].
Now I am sure there's lots of oriental mumbo jumbo about why a hammer like this is better then a solid steel one but I sure don't see any benifets and some reasons why it would not be as good. Is kind of neato and pretty if you like such things and if only used for light work would probably hold up OK if not used extensivly.....Todd
Re: Japanese Hammer
Re: Japanese Hammer
ThomD
>I think there is Occidental MJ about this also. Where on saws this method of mounting as well as being possible is also though to give greater impact resistance when using a hardened chip.
On my saw setting hammer there are serrations that help move the metal and since the saw blade is already hardened, the small serrations are more durable if hard The face has to be fine enough to fit over the teeth, so all in all it doesn't hurt if it is really hard. Forge welding a tiny piece might be rater difficult since the size is so small it could all just fall off or burn up, at least in my hands. :)
I do think we all cling to modest distinctions, like why we use hand tools or what is different about scrapping vs. sanding. How honest is it to pretend these traditions and preferences are particular oriental toolmakers.
Re: Japanese Hammer
Re: Japanese Hammer
Fred Peake
>I got it in an e-Bay auction from a tool dealer in Japan.
Re: Japanese Hammer
Re: Japanese Hammer
wilbur
>Just so you know, this isn't really mokume. Mokume is many multiple layers of metals, which results in the appearance of lamination lines that are similar to wood grain, and is usually an aesthetic choice when it comes to Japanese tools. The lamination in this hammer is more functional than it is aesthetic.
In this picture, the mokume layers are the vertical lines in the body of the hammer. The horizontal lamination lines at the ends are between harder steel on the ends and the softer steel in the body of the hammer head, which is more like the lamination going on in Fred's hammer.
Re: Japanese Hammer
Now that's a Hammer...
Scott Burr in Ben Lomond, CA
>But, what would "you" hit with it?
Re: Japanese Hammer
Re: Japanese Hammer
Todd Hughes
>I think that hammer is made out of wrought iron with steel ends forge welded on. Was then polished and etched to bring out the grain in the iron and to show the difference in the steel faces. Wrought iron , esp. lower grades, has a very pronoucned grain like this that is brought out even more by etching it.
Could be laminated or "damascuss" steel for the body but this would not be the tradtional way to make a hammer like this while an iron body would be.
Mokume is normaly diferent metals joined together using either solder or brazing, this hammer head body could not be made like that because it would come across from the heat when you welded the faces on
You see lots of older hammers, esp. blacksmith made ones, that are done this way and if made out of lower quality wrought iron [like this one probably] that has lots of silaca in it if you polished them and then etched them they would look very simular to this hammer.
I made a small hammer like this a couple years and etched it up to show the pattern, posted photos on the Woodnet but unfortunaly didn't save the photo and gave the hammer away to some girl.....Todd
Re: Japanese Hammer
Re: Japanese Hammer
Marv....... Northern California Lake Co.
>Todd,
Was it a christmas present for "some girl"? Nice touch..I like it.
Marv
Re: Japanese Hammer
Re: Japanese Hammer
ThomD
>Could be. They do make laminated hammers also, I have seen examples where the metal stipes were different metals, and prominantly separate. If you really wanted something different, you could get you name written in a cannister laminated steel! There are some smiths woking with dissimilar metals today in the west where the end results are multi vivid colours.
I think the wraught iron look in Japanese tools tends to be where the lines are eroded. They etch it long enough that there are depressions where the layers meet. With a laminated approach one can get a smooth surface that when etched is smooth, but grain like. With dissimilar metals the stripes are visible even if the junctions aren't visible.
Re: Japanese Hammer
Wrought iron
Wiley Horne--So. Calif.
>Hi Thom and all,
"With a laminated approach one can get a smooth surface that when etched is smooth, but grain like."
I think this is exactly what Todd was talking about. Todd is right, by the way. That is a Masayuki hammer, with folded wrought iron (undoubtedly the old stuff) laminated with steel end caps.
Wiley
