Veritas small router *LINK*
>I bought this last year, and have used it once (reduced the width of our back entrance gate and had to deepen the strikeplate mortise to match), and found the same issue on which Chris Schwarz commented in comparing it to the Lie-Nielsen small router plane: under, in my experience, even relatively light pressure, the cutter tends to twist in the plane.
I've e-mailed LV, in hopes they've developed a solution, but wonder if anyone here has. I've considered roughing up the shank with coarse sandpaper, being careful not to reduce its diameter, or maybe seeing it there's enough meat to put a setscrew in the end of the clamping bolt (thus maintaining LV tradition - can't figure out how a rare earth magnet would help, and there's already a wavy washer on the clamping bolt), but hesitate to mess with it.
I'd rather not buy the more expensive LN router plane, or an old Stanley, used at close to the same price as the LV model.
http://blog.woodworking-magazine.com/blog/After+Hard+Use+LieNielsen+Vs+Veritas+Router+Planes.aspx
Re: Veritas small router *LINK*
ThomD
>I have three solutions for you:
- I noticed there appears to be a v cut behind the round cutter. Is it full height? One option is to put some lead foil or tape in there so the rod has full bearing along the gloove. Lead is very sticky and should hold your part. You could use something like rubber. You could also fill the V (if it exists)with epoxy, again to gain full bearing. Possibly just a scrap of SC paper in a fine grit would solve your problem if wedged between the bit and the upper slot.
- If there is a v back there, another option would be to manufacture a cutter that uses a square shaft, ot to braze some metal to the round one that can be squared lower down leaving the round where it goes through the draw bolt.
- A hole could be drilled and tapped into the draw bolt from the front and a set screw mounted there. The bit could have a flat ground on it for the screw. The screw would only require a setup initially, the draw bolt would still exert the main pressure, but the new geometry would be more stable.
Another option would be a sleeve of brass rod drilled out and placed over the projecting bar with an engagement with the cast lip on the body. This would just require a notch to be cut in the lower edge of the brass tube so it carried down the front only. This could have several screws on it to add additional engagement. This could be made on a wood lathe or drill press, if you don't have the serious stuff. This would be a easier if the rod were a standard size. It could look rather nice. If it was made of brass it would tend to raise the CG a little. I like this idea best.
Wiley Horne--So. Calif.
>Hi Bill,
Thom's got some professional ideas, which are best. If you just want it to work, take a piece of PSA sandpaper, fold it partway over so there's grit on both sides, and some stick'um on the back side, and slide it in there. If you got some PSA, and if it fits.
Reminds me of the old saying: If we had some ham, we could have ham and eggs, if we had some eggs.
Wiley
Pam Niedermayer, Austin, TX
>Along these lines, how about some resin applied to the shank or, if there's room, a piece of the thin tape that's used to remove slip on hand grips, like for tennis racquets.
Pam
ThomD
>I suggested paper also, great minds think alike. Sometimes just some powder in the work will give enough grip. Something floury, but hard, like chalk.
>Just found the powdered rosin recommendation in the comments to Chris' article. Sorry for the repetition.
Pam
It was good you called it out,
>I missed it the first time. Thom had a very similar thought, so as he said, "great minds.....". Repetition is good for us speed readers (and speed listeners too).
I love problems which have solutions like 'slide some sandpaper in there', or 'put some rosin on it', or 'if it's round, put a flat on it'. Rock talk kinda stuff.
Wiley
Bill, the answer ...  *LINK*
>... may be to try one of three things (or all).
Firstly, I too commented on the clamping result in my review:
The Veritas design has one negative point in my opinion, this being the absence of provision for the blade to be locked in position. The Stanley, by comparison, has a groove running the length of the blade shaft into which the screw fits. This holds the position of the blade position. While it is a relatively simple matter to correctly orientate the Veritas, it does require moderate locking tension to prevent movement. Once this is done I did not experience any such problems.
At this time the LN was not out so I could not compare the three small routers. I have since had quite a bit of time with the LN (which uses a square shaft), and all three have their pros and cons. There is no clear "best". Still, to your issue ...
The first solution, which was all I had to do, was finger-tighten the knob more than expected. We expect to be able to tighten sufficiently with the router plane sitting flat on the bench. However you will not get enough purchase. First tighten on the bench, then lift it and give it a final squeeze (This is just a tad more. You are not trying to secure the Queen Mary). That is enough for me.
The second solution is to check your curvy washer.
For those who are unaware, the Veritas clamps the blade with the aid of a spring-loaded �wavy� washer. This enables the blade clamp to exert a variable degree of pressure on the blade. The blade locking knob can be loosened, and the clamp will continue to apply sufficient pressure on the blade shaft to hold it in position. Press the blade locking knob inward � towards the blade � and this will release the blade completely.
Experiment with reversing this washer. The washer forms a dome, so it may be directional. I found that when the washer added a tad more security in one direction over the other. It was not a significant issue for me, but it may help you.
Thirdly, your "V" channel may be too smooth. I took a steel scribe and scratched vertical lines in the channel. This added further holding power.
All-in-all, these strategies are additive. My small router is just fine. I have no issues with it.
There is a link below to my review, which probably predates Christopher's. I think that ALF also did one, and her reviews are always a delight to read.
While you are fiddling, here is an extra - build yourself a depth stop for the small router. I got this idea from the large LN router plane (the one area in which I preferred the LN to the Veritas). None of the small router planes (LN, Stanl;ey and Veritas) come with a depoth stop. I find a depth stop indispensible for ease of working.
And on the large Veritas router plane. This makes for very fast blade adjustments.
Let us know how you get on.
The Veritas Small Router Plane - review
Re: Bill, the answer ...
Patrick Gibbons, Katy, TX
>Derek, I really love your depth stop for the small router. I have both the Stanleys and find the idea of a depth stop for the small router to be very appealing. Very creative on your part.
Re: It was good you called it out,
>Yeah, but the problem is I'm often accused of reading a solution on one forum and reporting it on another. I've never done such a thing without attribution, but I'm gun shy, better to apologize/attribute in advance.
Pam
It's all good!
Hey Derek ...
Christopher Fitch @ Memphis
>could you provide some details on how you made those two stops?
Or maybe the types and sources of the hardware?
ThomD
>Your depth stop Derek, is very similar to what I was suggesting. With the addition of a notch at the base it would act as an anti-rotation device, and as you have already proven, as a depth stop.
Hey Christopher ... *LINK*
>Hi Chistropher
All you need is a "ring" and a "screw".
I am a scrounger and collector of bits-and-pieces that I think may be converted into something useful. Look at the Link below for ways to make your own lever cap screws.
So find something tube-like that will slip neatly over the blade. For the small router I used a steel rod that conveniently had a hole drilled to fit the blade. For the large router I cut off a section of a brass hose clamp. The thumb screws - the small one came off some fitting, can't recall. The large router is actually a LV spare knob into which I epoxied a bolt. Then I simply tapped the relevant holes to match the threads in each of the sleeves. Hey Presto!
Making Lever Caps and Lever Cap Screws in the Back
American alternatives
>The stop for the small router looks like a "throttle stop," which some auto parts stores may still stock, though I'm not sure they come with a 1/4" hole.
