drying tree slices????
George in Lowell, Mich
>Hi all,
After you cut a slice about 2" thick off a log (with a crosscut 2 man saw), how do you prevent it from cracking?
Thanks
George
>Hi all,
Thanks
George
Re: drying tree slices????
ThomD
>I would throw it in a garbage bag with a lot of wet sawdust or chips. They gradually, increase the drying rater. Take it out of hte bag for a while, put it back in. If you want ot speed things up you could vac bag it.
What makes for splits in the end of a log is that the end dries faster than wood deeper in the log, so the deeper wood is thicker with water, and this causes the end piece to split since it has lost relatively more water. If you cut the end off it will dry more uniformly and therefore be less likely to crack, and it isn't attached to wetter wood at one end. If you coat the endgrain, both sided, it will reduce the rate of moisture loss, but depending on how valuable and irreplaceable each piece of wood is it may be worth trying un-coated wood since it will dry decades faster.
You would want to encourage equal drying conditions. So not put one face down and the other up, with the upper one exposed to a draft, and getting a lot of sun...
It helps to cut the end slice, if possible, on an angle. This increases the strength of the end piece,because there is more grain length for a given thickness.
David Cockey
>Wood wants to shrink more circumfentially than radially as it dries. Think of the rings as hoops. They are getting shorter more than the corresponding reduction in radius, so the rings are trying to be pulled apart. With enough moisture loss a crack running radially will develop no matter how slowly it's dried. One way around it is to soak the wood in PEG which will replace the water and prevent shrinkage.
pick the right tree
Bill Tindall, E.TN
>David's answer is in fact correct so to prevent a crack you need to select a species where the radial and tangential shrinkage is nearly equal. Of course the smaller the log the greater the likelihood of success. White pine may do ok . I have seen some fairly large sycamore slices.
Re: Or
ThomD
>Not an absolute rule seen plenty of cases where it can be done. Like every Japanese chisel in my shop, and larger pieces of course.
If working with the species that will crack. pre-cut the crack then re-join later, choose an area where there aren't any crossgrain cuts, it shouldn't be noticeable.
Another option would be to band it during drying. The fact that there are unresolved stresses doesn't mean it will break. I've sawn board that violently released when sliced into, they kept it together despite enormous stresses.
Another option would be to band it and then steam it. Steam drives out moisture and plasticizes the wood, which might allow some accomodation to occur, or not.
If you only need one side to be visible you can drill out material on the back to reduce internal pressure.
With vac bagging it is possible to differentially remove water. More from the center. The same would be true of steam. Place it over a smaller pot and let it rip on the central area.
But hey if it's all impossible...
(I can think of at least three other methods, but I think they start to be less practical than PEG, if that is a possible winner in this application. Never liked the sound of it's decribed waxiness enough to try it. It would depend on the OPs actual needs.)
Re: what is PEG ???
George in Lowell, Michigan
>Hi,
Thanks for the responses, you've given me alot of directions to go.
What though is PEG? Does it prevent or hinder shellac, varnish, oils, etc.? I've used latex house paint on logs than I was going to have cut into lumber. I think it helped slow the drying althouhg they still cracked.
I am using walnut to make a small 3 legged stool.
Thanks,
George
Polyethylene Glycol
Paul Kramer
