THE WOODRAT IS BACK!
Sandin' , Sharpenin'..
John L. Blue
>Is sandin' wood the same as sharpenin' knives? from coarse to fine?
Re: Sandin' , Sharpenin'..
ThomD
>In either case one starts with the finnest abrasive needed to make the required change, and proceeds through to the finest abrassive required for the end result one wants. There are differences in how it all works but that's the basic. Same thing with hand tolls, start with the coarse, move to the fine.
additionally.........
Bill Tindall, E.TN
>when descending the grit sizes a rule of thumb is to skip one of the available sizes . So, for example, paper comes in sizes- 100,120,150,180,220, 240. etc. If you start with 100, next would be 150 and then 220...... or 120, 180,240. That said, if I need to start at 100 I usually follow with 120 because it is hard to get 100 grit scratches out of some woods like maple with150 grit. In terms of time, the most of your sanding should be with the first grit chosen. This grit will be removing machining defects and they are harder to remove than a previous grit's scratch marks. If you don't do a proper job with the first grit you will likely never fix the deficiency with the finer grits. Same for sharpening..............
restricted choice
paul womack
Pretty much *everything* is coarse to fine.
Planing, golfing (drive, chip, putt), building a road (dig, grade, surface)...
BugBear
Re: restricted choice
Pam Niedermayer, Austin, TX
>Excellent point, Paul. Everything that's not coarse to fine would be fine to coarse, like extrapolating from the particular. :)
Pam
