Finally, some movement on the workbench!
Stuart Hough
>Today I finally had time to go to the Orange box store and get the raw materials for my FIRST REAL WORKBENCH (heretofore to be known as the FRW). I am using SYP as suggested by Sir Chris Schwarz in his article on the $175 Workbench. I spent almost two hours sorting through the stacks 2-by-8's, 2-by-10's and 2-by-12's. I only found two that would serve me well enough, with very few tight knots and grain that would have the right orientation after sawing (quartered or very near). I had noticed earlier that the BORG now carries 5/4 SYP in 4" by 12' lengths. So I started looking through that pile, and was able to get all I needed to build the top. My plan is to use the 5/4-by-4's for the bulk of the top, and use a 2-by for the strip where the dog holes will go. Also I will use a 2-by for the front and back laminations. Overall thickness will end up between 3 and 3.25 inches. Now for the questions that need answering...I will be letting the lumber acclimate to the shop for approx 2 weeks before starting to mill the "stuff". I have it stickered and stacked, but am not sure of the spacing required between the stickers. I currently have them at about 18" apart. Is that too close, or about right? Also, I am using plywood for the stickers, set on the face. Is 3/4 " enough of a gap between the boards to allow for airflow? I appreciate any and all bits of advice on my FRW. Let me know what any of you think about what I am planning, and any changes you would make. Thanx to the collective!
