Veritas - Innovation in Tools
Stanley 81 vs. 80
Stanley 81 vs. 80
Stanley 81 vs. 80
>I may go to a garage sale today. The Craigslist pictures hint at a Stanley 81. Any virtue to these over a more pedestrian 80?
Re: Stanley 81 vs. 80
Larry Williams
>Bill,
The #80 is the jack plane of scrapers and the #81 is the real nice finish plane of scrapers. As long as you don't need to get close to an adjoining vertical surface where the handles get in the way the #81 is the best scraper Stanley made. I like it a lot better than a #112 which I find clumsy and sometimes painful.
You talked me into it, Larry
>Not that it was necessarily hard; going slightly batty with this recovering from surgery business.
The seller had a friend help him set prices, and they clearly live on some other planet. This was tagged at $75, about twice eBay prices; but he collapsed to $25 (below typical eBay) without any nudging at all.
Interestingly, it's got a Disston No. 120 blade.
Mike Hamilton
>Isn't the 81 'malleable iron' or some such? (won't break when it hits the cement floor)
Mike
Todd Hughes
>The 81 is slightly smaller then the 80 and has a wooden sole which may make it go smoother over your work...will also wear over time too. Is a fancier plane and worth more then a 80
An 80 has a tensioning screw for the blade which the 81 doesn't. You can get an 80 [80M] in maleable iron so if you like to drop your planes it probably won't break...can't get a 81 in maleable iron
Both are just simple tools that hold a blade so it can be dragged over a piece of wood. I doubt anyone can look at your work and say.."thats been done with a Stanley 80 and not a 81" or that you can do somthing with one that you can't do with another.
I sure see more 80s then I do 81s which I guess tells you which one the old timers wanted.....Todd
Re: You talked me into it, Larry
Bob Demers
>Bill
Good score. $75 was'nt too unreasonable, if it had the original blade (often missing) and the rosewood sole in good condition (often missing or crudely replaced.
Even with these two faults, $25 would still be a gloat, So I see that you are recovering nicely :-)
The 81, is a nice finishing tool, prepare the blade as you would for the 80 except that keep in mind that you have no control over the blade (bowing) to adjust the cut. You may have to experiment with whatever burr work for you. Just dont expect it to take big shavings like the 80.
The blade incidently, is an odd size, the No 80 wont fit it. Hence why one with the original Stanley blade worth more. They were often unmarked BTW, so when they have a nice SW sticker on it, they are worth near $100+.
So there you go, enjoy you're new finishing scraper, I really like mine.
Bob, who has a few of Stanley products just because
One trivium
>On the "frog" of this tool - the face against which the scraper blade is clamped by the equivalent of a lever cap - Stanley riveted what looks from the edge like a steel face (closer examination would require driving out the pins from the pivoted "lever" - actually, screw - cap, and I'm not THAT interested). This is a later model - notched-rectangle logo. I don't know if this steel facing was intended to strengthen the tool where the screw of the cap puts its pressure because the casting was cracking, or if there is some other engineering problem being solved here.
That's the "80M" Mike
Scott Burr in Ben Lomond, CA
>The 81 is nickel plated and has a rosewood sole.
