Worksharp
Worksharp
Worksharp
John Hoffman
>Hi all,
I just got a worksharp and have been messing with it. Problem was that the chisel port was not parallel to the glass plate thus causing a skew grind. It took about an hour and some good amount of metal to get the thing adjusted.
Is anyone else having this problem? Am also wondering what grit people are using to hone. It came with 3,600 but they offer 6K and a leather wheel. Thoughts/advice?
Thanks
John
Re: Worksharp
Re: Worksharp
Greg B�tit, Crown Point, NY.
>I got one for Christmas. I used it on the Lie Nielsen set of chisels I got last year for Christmas (beep beep?). No problems with the skew issue you mentioned. Mine came with the leather honing wheel, which I found to to be a requisite. In retrospect you probably could use a regular leather honing stop w. buffing compound, but the last sandpaper grit is not where I would want to stop.
greg
Re: Worksharp
Re: Worksharp
John Hoffman
>My machine will not square an edge no matter how I move the skew adjustment. I will contact them to get it fixed.
I want to try the leather wheel or the 6K abraisive.
JH
Re: Worksharp
Re: Worksharp
Nikos
>I have the same problem. I tried to adjust the skew. It seems that I overcompensated and now I get a skew in the other direction. So, I must continue adjusting until I get it right. I wish I knew how the adjust the squareness at the factory.
Re: Worksharp
Re: Worksharp
John Hoffman
>Hi,
I can not get it to skew the other way. No matter what I do it continues to skew the same way and cause a high left side.
Here is a tip I saw. Use a piece of pine or other softwood which won't cause the same problems as grinding metal. I jointed the side of the wood piece and placed it against the right side of the chisel port fence I then drew a line accross the wood with a square and then plunged it into the chisel port. I kept adjusting the skew lever until I get it squared.
Hope that helps.
I agree that they should do a better job at the factory.
JH
