new project- a table
Bill Tindall, E.TN
>This project is an example of my melding of hand an power tools.
We eat on the front porch and watch the sun come up (in warmer weather, its snowing now). We need a coffee type table for this activity. Furniture design is not one of my talents but every now and then I have a fit of creativity and try something, that works now and then.
Shown is what will be the top of the table. My intention is to install these pieces into the frame with a tenon on the end of the puzzle pieces and a groove in the frame. The puzzle pieces will be in the same plane as the top of the frame, I think. So how to mark and cut the tenons so in the end everything fits right?
So far everything in the picture is done with power tools excepting some spoke shaving for fitting the puzzle pieces which I found to be very difficult What I found is that minor adjustments of one piece of this puzzle throws off the alignment of all the others, sometimes a lot!. In fact I was astonished at how far off the assembly could be each time I readjusted it. "A little bit" times 10 becomes a lot, I guess.
I bradded the puzzle pieces to a piece of plywood which fixed their position as I desired it or at least close enough. Then I laid the dry fitted frame onto the assembly, as show. Next I will scribe the outline of the frame on the puzzle pieces, remove the frame and cut the tenons on the puzzle pieces which will ensure they will be aligned when I put it all together. I will chisel (I chisel better than I can saw) to the scribe line (actually already have) which will result in a perfect fit (I hope).
I expect I will gently curve the sides and ends of the frame and probably round its edges to a bull nose or half round. Haven't decided on the legs. Anyone have ideas for legs?
Oh, the wood is white oak cut by a dear friend who has since died.
